thicker headgasket?
Old Nov 29, 2008 | 11:55 PM
white ej2's Avatar
Default thicker headgasket?
I have a b16a that i want to turbo and since the motor has relatively high compression i was wondering if it would be possible to lower the compression down to about 8 or 9:1 with just a thicker headgasket since i really dont have the money to build the motor. My goal for the car is about 300whp and since its my dd i want to make it as reliable as possible. Thanks in advance guys.
Old Nov 30, 2008 | 07:59 AM
95dxsir2's Avatar
i have the cometic .074", should be around 9.3:1
have you thought about using water/meth injection?
Old Nov 30, 2008 | 09:59 AM
Ls_dx's Avatar
Yes you can run a thicker gasket to lower the compression. Also you are going to have to tune it/ Have it tuned. And premimum gas would be a good idea (no brainer to me)
Good luck!
Old Nov 30, 2008 | 11:35 PM
quicksilver1689's Avatar
i ♥ snails
all these damn gasket threads, 300whp stock compression, no problem. Leave it alone
Old Dec 1, 2008 | 09:40 AM
Schister66's Avatar
Man U FTW
I agree. Just stick with the stock compression and boost the damn thing. Get a good tune and build an efficient turbo setup...you wont have problems. The end...
ojasia
Jul 13, 2014 08:24 PM
motormike40
Aug 17, 2007 04:38 PM
madman604
Jun 2, 2003 11:09 AM
VTEC-DA
Jan 18, 2003 02:06 PM
