IHI VF34 Question?
Old Dec 2, 2008 | 12:32 PM
sohcT's Avatar
Icon6 IHI VF34 Question?
I have an IHI ax53 b60 P18 turbocharger on my 1997 civic lx with a built bottom end d16y7 (non-vtec). This turbocharger is from an apexi sohc turbo kit. I've had this turbo on my car for 7 years and absolutely love the powerband. I was wondering if an IHI VF34 would be a direct bolt on to the hotside housing of my apexi turbo as both have P18 exhaust wheels? Has anyone ever done this? Would this be worth the upgrade?
Here's a current pic of the bay
and current dyno
I would like to see if this would be a slight upgade and I would also prefer to use my same downpipe.
Old Dec 2, 2008 | 02:44 PM
TheShodan's Avatar
Moderator
I am quite sure that is not a possiblity. Ishikawa always had different housing and turbine wheel developments that don't share anything with one another, from the WRX to the APEXi kit.
Old Dec 2, 2008 | 06:43 PM
Drew Peacock's Avatar
most of the ihivf turbos are bolt on swaps with each other as far as the manifold and down pipe are concerned, intakes are a bit different but that is fairly easy to get around.
For example the ihi vf8, vf10, vf12, vf22, vf34 are all interchangable.
Op does you turbo have a intake like the vf22 in my avatar? If so I would imagine it would be a bolt on affair.
I would just swap the whole turbo.
Old Dec 2, 2008 | 07:05 PM
sohcT's Avatar
Thanks for the replies. So, the VF34 would have the same 5 bolt downpipe flange as the apexi? Would it be worth the upgrade? Don't the VF turbos have 3 bolt manifold flanges?
Old Dec 3, 2008 | 11:28 AM
TheShodan's Avatar
Moderator
Like it was said, some have 3 bolt, some don't. It may be easier to show the turbine side that you have for a better comparison.
Old Dec 3, 2008 | 01:10 PM
sohcT's Avatar
crappy pic but maybe this will help. i appreciate the replies.
Old Dec 3, 2008 | 10:30 PM
Yeah all those turbos are 3 bolt and the downpipe does appear to be different its the other way round. Keep what you have and get a aggressive cam increase the boost and use race gas for higher boost levels. I bet most of the time you don't need hi boost anyway so response is always a plus.
Old Dec 4, 2008 | 12:45 AM
quicksilver1689's Avatar
i ♥ snails
go big or go home
Old Dec 4, 2008 | 06:23 AM
SOHC_MShue's Avatar
Yep doesn't look like it will be a direct swap for the turbos. My vf39 had that funny 3 bolt inlet exhaust flange.
Old Dec 4, 2008 | 02:20 PM
sohcT's Avatar
Originally Posted by quicksilver1689
go big or go home
Ha!
I just may! Thanks guys. Any new turbo suggestions? 320whp would be more than enough.
ham
Jan 17, 2010 07:56 AM
sohcT
Aug 14, 2007 03:14 PM
lowpsi
Jun 22, 2002 09:57 PM
