Drilling turbine housing for larger (1/2") Studs ??
I have a turbo manifold that has 1/2" studs installed in it. the issue is the bolt holes on my Garrett t3/t4 are about 3/8"s
is it okay to drill the turbine housing out to accept the 1/2" studs ?? anyone done this ?
Man U FTW
Its a cast iron housing, you can pretty much do what you want. Take the turbine side off the rest of the turbo to avoid foreign debris getting into it. Other than that, you should be in business...
Just make sure the holes aren't enlarged too much that the nut doesn't have enough area to get a positive grip on... Last thing you want is to convert to allen bolts and remove all those 1/2" studs...
"Last thing you want is to convert to allen bolts and remove all those 1/2" studs... "
Im not sure what you mean ? are you saying I should convert to Allen head bolts ? or that I might in the future ? why would I want to do something like that ?
make sure there is enough room on the nut side of the housing for you to tighten it all the way down, a 1/2" bolt has a pretty large nut......
zojirushi
12-02-2002 08:54 AM
