VTEC problem in boost
Old Dec 14, 2008 | 10:43 AM
219DAdriver's Avatar
Default VTEC problem in boost
Last night we were tuning my buddies f22 boost setup. When we enabled vtec it hit but threw a CEL code (21) and only lasted the rest of that gear and not the others he says. Anyone else have this problem or can help him get this fixed?? Any useful advice is greatly appreciated...
Old Dec 14, 2008 | 11:09 AM
90blackcrx's Avatar
Little more info on the setup, what are you using for tuning ?
Old Dec 14, 2008 | 11:31 AM
We're using Crome for tuning. His setup is on a stock block/head on 9psi at the moment. 550cc injectors, log manifold with a 57trim T3/T4 turbo
Old Dec 14, 2008 | 11:41 AM
ABK's Avatar
ABK
does the car drop out of vtec when that happens?
Old Dec 14, 2008 | 05:16 PM
he says if he pulls from first gear the CEL wont show until he hits third gear sumtimes. everytime he does a second gear pull, after vtec engages it throws the code and it doesnt engage in 4th and 5th
Old Dec 14, 2008 | 05:32 PM
rintegration's Avatar
Make sure the engine has oil & good oil pressure.
Old Dec 14, 2008 | 08:08 PM
added bout a half of qt oil more than usual when i changed the oil before tuning
Old Dec 14, 2008 | 08:59 PM
fishieman's Avatar
Why don't you start with the CEL 21 first before moving onto something?
Old Dec 14, 2008 | 11:19 PM
ABK's Avatar
ABK
Is the vtec oil pressure switch enabled on the rom (it checks to see how much oil pressure is going to the vtec solenoid)? Oil pressure gauge on the car? Hows the wiring?
Old Dec 15, 2008 | 04:25 AM
boosted k20's Avatar
try to disable the VTEC pressure sensor (code 22 actually) and also connect pin A4 and D6 together
Old Dec 15, 2008 | 07:37 PM
i dont think you can disable the vtec oil pressure switch on Crome. He doesnt have his oil pressure gauge installed yet (personal decision). currently we're tryin to get the solenoid bolts out and clean the screen and he said he is goin to check the ohms in the power goin to the solenoid.
Old Dec 15, 2008 | 11:12 PM
ABK's Avatar
ABK
yea you are right about the option in crome. Check the screen and have him invest in oil pressure gauge. Don't want to kill the engine or the turbo because of oil pressure issues. Maybe the wiring is bad in some spot and whenever the engine shifts it breaks open.
Old Dec 15, 2008 | 11:50 PM
turbod da's Avatar
by connecting this two together,is the ecu suppose to bypass
it? meaning the ecu would think pressure is good and therefore
engage vtec?
courios to learn,as this can help figure or test it someway....
Old Dec 16, 2008 | 04:55 AM
Yes thats exactly why. and yes, u can disable VTEC pressure code 22 with crome(i know u r throw n code 21, but one can lead to the other). i have disabled it many a times already
Just place a jumper wire between pin A4 and D6
Old Dec 16, 2008 | 05:03 AM
1EG2NV's Avatar
my friend had the same problem on the dyno last week. The ecu was sending voltage to the vtec sol. but the problem ended up being mechancial. Pulled the sol. off and the screen was full of metal( i know, not good). We tried cleaning it out but that did not help. Put a good used one on there and we were back in business. Hope you figure it out bro.
Old Dec 16, 2008 | 08:28 AM
rico892002's Avatar
yea guyz its my car. i checked all the wire everything is good. when the car was n/a it never did this. like my buddy was saying when i hit vtec it engages then the check engine light comes on and vtec cuts off. i been spending alot of money on this car and i dont want to be buyin a whole lot of extra **** if i dont need it. im going to try and take the solenoid off and give it a good cleaning and also ohm the solenoid and see what it reads.
Old Dec 17, 2008 | 02:26 PM
thanx for the input guys...we all kno this car hobby can be a headache sometimes. LoL gotta love it...
Old Dec 17, 2008 | 05:57 PM
ABK's Avatar
ABK
Yea tell me about it... That's why the punching back is going up this spring. I can't rememeber how many times a month I have to go and start punching the door to my garage. Key thing is not to give up, you are smarter then a car.
Old Dec 17, 2008 | 06:03 PM
93turbo16's Avatar
Are you using a converted ecu?
Say a P06 or P05 that was converted to vtec?
If so, sounds like a wrong transistor inside the ecu.
Old Dec 18, 2008 | 08:26 PM
yea, frustration is a common emotion when building projects. LoL
Old Dec 18, 2008 | 08:28 PM
yea he using my ecu...its a converted P06. it never threw that code in my car tho. my vtec worked fine.
Old Dec 19, 2008 | 01:59 PM
rico892002's Avatar
no charles that ecu is a pr4 converted
Old Dec 20, 2008 | 03:16 PM
my fault... yea, wut he said
Old Dec 20, 2008 | 03:35 PM
90blackcrx's Avatar
Just bypass the oil switch in the engine bay.
Old Dec 21, 2008 | 03:29 PM
Default Re: VTEC problem in boost
is there a possibilty that the oil pressure drops when the turbo spools in boost, in addition to vtec engaging? he has no oil pressure gauge hooked up so its not obvious or nething...
