what turbo do i need???
Old Dec 1, 2008 | 04:07 PM
2fastek's Avatar
Default what turbo do i need???
i have a 84.5mm sleeved gsr block that im boosting and my goal is anywhere from 475- 550 hp on no more than 25-28psi boost. Money is not an option cause i plan on doing this right the first time, so ill spend watever for a reliable set up. What turbo dhould i run that wont have that much lag and wont give me clearance problems for a/c? Thanks in advance!
Old Dec 1, 2008 | 04:10 PM
SPOOLINmatt's Avatar
s362?
Old Dec 1, 2008 | 04:23 PM
2fastek's Avatar
who makes that turbo?
Old Dec 1, 2008 | 04:41 PM
tortuga89's Avatar
i thing Precision
Old Dec 1, 2008 | 04:45 PM
caughtbycops's Avatar
i beleive matt means a borg warner s362 turbo
Old Dec 1, 2008 | 05:03 PM
2fastek's Avatar
i plan on running this manifold you guys dont think it will have clearance issues with a/c?
or this one, and would this manifold reach my power goals also?
Old Dec 1, 2008 | 05:12 PM
yeah my bad, Bullseye/Borg Warner S362.
Old Dec 1, 2008 | 05:25 PM
ievaq8's Avatar
im using this manifold in my dc2r although it is LHD in Australia, i still retain aircon and power steering.
i am using a gt3037s garret ball bearing turbo.
i hope this helps.
Old Dec 1, 2008 | 10:51 PM
project dc2's Avatar
our log manifold will not help you reach those powergoals
i'd recommend this we had a similar design ( short runner length) on 1quikgsr's car and it made 520 on 19 psi on an SC61 t3 flanged turbo on an 84MM block
** the manifold posted above is ac compatible***
of course we have our other manifolds for non-AC setups just PM us to view your options
full-race is an excellent option also of course**
as for turbo i'd go garrett GT40R or as previously stated S362
Old Dec 3, 2008 | 06:05 PM
2fastek's Avatar
If i were to go with a precision sc61, would that require more boost to make 500hp that the s362 turbo?
Old Dec 5, 2008 | 10:50 AM
2fastek's Avatar
bump
Old Dec 5, 2008 | 01:26 PM
TheShodan's Avatar
Moderator
Yes. in a way. If the engine is as sleeved as you say, then the amount of "pressure" is not going to be that relevant,so that shouldn't be a problem. For each pound of pressure injected into the intake manifold, there is about 15 degrees of additional heat that is also injected. This could lead to detonation. The Extended Tip Technology of a BW turbocharger (where the inducer is actually taller by about 20 percent) allows one to run more pressure, but with lower Intake Air Temperatures.
Old Dec 6, 2008 | 07:16 PM
2fastek's Avatar
see money is not the issue, but at the same time im not trying to waste any. Bw turbo is more money than a sc61. so will the bw make more power with less boost than the sc61 cause if they make the same then im going with the precision?
Old Dec 7, 2008 | 10:12 AM
TheShodan's Avatar
Moderator
Yes, the S362 is a more efficient turbocharger per lbs/min than an SC61. The Sc61 is the same as the T61/GT3540S/ etc.
Stop looking at the power based upon just boost. There is much more to getting an efficiently large amount than boost alone.
Old Dec 7, 2008 | 11:11 AM
DLB1994's Avatar
if you want a t3 base turbo , and you dont mine spending a few bucks get a gt35r , but for cheaper with out the same spool up with close power is a t3/gt40.
Old Dec 7, 2008 | 11:51 AM
i have a t4 t67 that i am selling BTW. Its been a very efficient unit!
Old Dec 7, 2008 | 06:40 PM
2fastek's Avatar
thanks guys
Old Dec 7, 2008 | 07:31 PM
K i l l a B e e.'s Avatar
475-550? is this gonna be daily driven? the reason i ask is because u said you wanted to retain AC.
Listerofsmeg
Mar 25, 2010 12:46 PM
Integra_drk
Mar 25, 2008 10:34 PM
gawath
Sep 18, 2005 12:14 PM
darylfiend11
Jun 11, 2004 12:59 PM
importboi22
Jun 15, 2003 04:24 PM
