Cams for Turbo Set-up
i was looking into aftermarket cams for my set-up but i am not knowledgeable that much on cams as far as on stock block, was looking at the Skunk2 Pro Series 1 Cams, but then noticed there was a Skunk2 Turbo Series 1 set of cams for low boost between 5 and 10 pounds and another for higher boost. My main question is should i go with the turbo cam set? is the Skunk2 Pro Series 1 cams only for all motor or what? My set-up is below:
Engine: B18c1 GSR
Peakboost Ver 1 Turbo Kit 50 Trim turbo at 8 pounds
Skunk2 IM and 68mm TB
GM 3 Bar Map Sensor
Hondata S300 Tuned
3" Exhaust
If anymore info is needed just let me know open to all help and criticism.
Engine: B18c1 GSR
GM 3 Bar Map Sensor
Hondata S300 Tuned
3" Exhaust
I made 675whp with ITR cams. They work great, are fairly priced and readily available. They have been proven time and time again. For a setup like the one posted, ITR cams will work great.
