fully built low comp pass smog?
Old Dec 15, 2008 | 06:23 PM
slimjimming6688's Avatar
Default fully built low comp pass smog?
i have a b16 fully built block with low comp pistons, and its a bare block rite now but will soon be put together. scence the pistons are low comp dish style.. i want to know if it will pass obd2 smog test with the low comp and stock ecu from a 99 si. i was thinking i need to swap out the pistons for a flat one like oem but from JE piston, i dont have a lot of money so id like to do it in one shot.
block spec
B16a3
bencin sleeved
knife edged crank
JE 9 to 1 81mm pistons
crower rods.
Old Dec 15, 2008 | 06:25 PM
SovXietday's Avatar
Should be just fine, just make sure you have stock injectors and a cat.
Old Dec 15, 2008 | 06:30 PM
ohh ok so with the low comp pistons it wont run funny with the stock program?
sucky cali law
Old Dec 15, 2008 | 06:44 PM
tegman23's Avatar
No as long as you have stock ecu and injetors...the compression wont make it run weird..
Old Dec 16, 2008 | 06:35 AM
so ill have clean gas readings too?
Old Dec 16, 2008 | 06:51 AM
96 GSR-T's Avatar
you will pass the tests, dont worry about it, the stock 02 and the cat will do what they are supposed to do............
Rickdogg
Apr 26, 2011 01:29 AM
_inline4turbo_
Apr 30, 2009 08:06 AM
slimjimming6688
Dec 15, 2008 08:23 PM
PrOjEcT_LuDe
Sep 21, 2004 01:28 PM
Luserkid
Aug 3, 2003 03:30 PM
