my b18b
Old Dec 11, 2008 | 03:11 PM
93 Eg Couper's Avatar
Default my b18b
stock block b18b in eg coupe
going boost next week
im looking for 350-370cc injectors or so, fuel pump and thats all she wrote
only looking for 8-10psi with stock internals on a Garrett T3/TO4E 50 trim w/ .48 or Garrett T3/TO4E 57 trim w/ .48 a/r... whats better? 50 trim or 57 both being .48ar
looking for better with my stock block and fuel upgrades couldn't find a thread on this specific deal so thought i';d ask
Old Dec 11, 2008 | 04:30 PM
redlsvtec4door's Avatar
go with atleast 550cc injectors (they will be good for atlest 350 hp)
and a walbro 255 lph hp pump
as for turbo go with a 57 trim. hands down. ls's dont breath enough for a small turbo to make high rpm power
Old Dec 11, 2008 | 05:30 PM
well i understand the get a 57 trim turbo
but 550cc injectors and im aiming at 230-250 horse.. wont these be too much fuel and run it rich?
Old Dec 11, 2008 | 06:07 PM
cockerkid008's Avatar
when you get it tuned they will fix it
they say once you go boost you will always want to turn the boost up
Old Dec 11, 2008 | 06:21 PM
okay well then if i want to add boost the injectors will be large enough to withstand the more pressure and get a re-tune, correct?
Old Dec 12, 2008 | 02:28 AM
blackeg's Avatar
never get a fuel injector that will be at full capacity with your initial goals. i can guarantee you will have to spend more money on bigger injectors, in your case even if you wanted 2 more psi of boost.
the car can be programmed to the right amount of fuel when you get it tuned.
i ran the 57 trim .48exhaust on a stock ls motor. 10 psi with both 550cc and then 780cc injectors. it was all in the tuning.
side note: ive probably had 10 different motor/turbo setups and combos over the past 6 years, ranging from 180hp to 425hp+ and by far the most fun setup to drive around was when i had that 57 trim on a stock ls motor in a civic coupe. 10 psi by like 3400rpms, and pulled all the way to 7500. you could even hear it spooling up through the exhaust like a jet lol.
Old Dec 13, 2008 | 11:47 AM
blackeg...
your saying i should buy at least 550cc injectors even if i want only 10psi to make 250whp?
and then the tuning can lower the fuel injection rate depending on my boost etc...
and when i up the boost, i get it re-tuned and speed up the fuel injection rate?
correct?
Joe-G
Jun 7, 2010 11:32 PM
V8Hunters
May 2, 2006 07:07 AM
w
May 6, 2005 07:11 PM
819turbo
Feb 9, 2004 12:14 PM
Mr.DC2TurBo
Nov 14, 2003 08:59 PM
