tuning problem, or setup?
Old Dec 1, 2008 | 04:38 PM
THEDirtyDseriesWOOT's Avatar
Default tuning problem, or setup?
ok posting this for a good friend
he got tuned yesturday
b18c1 sleeved
golden eagle assembled
gsr head ported by rlz
pro1 cams--edited they were stock gsr on the dyno .. has not put them in yet
skunk 2 valve train
inline pro manifold
ac and ps
sc4427E
Rc750cc injecotrs
walbro intank
got it tuned @19psi 93 octane on a dyno dynamics .. it reads lower than most
316whp
354 ft lbs
why is the whp so low>?
and that tq is monster high for that boost level on that dyno..
any thought into what would make the numbers fall like this..
Old Dec 1, 2008 | 04:39 PM
please tell me some things to address so i can get him in the right direction
Old Dec 1, 2008 | 04:40 PM
he also tried to put c16 in and tune it at 26psi anything over 22psi it was blowing spark out is what the tuner told him.. i thought the stock ignition was better than that
Old Dec 1, 2008 | 04:53 PM
SOHC_MShue's Avatar
pics of the dyno graph? Also do you have a plot of the boost curve? It sounds like its laying over bad up top to have so much more torque than hp. There could be a serious restriction or boost is dropping big time.
Old Dec 1, 2008 | 05:06 PM
Bugermass's Avatar
Post the dyno graph.. The spark can blow out for a number of reason.. Too much retard, Too much fuel, to big a spark gap for the combination of retard, fuel and mixture density, or the ignition system could just be worn out.
Old Dec 1, 2008 | 05:07 PM
miller's Avatar
There are a couple things wrong, first off i am not sure who is tuning the the car but the stock ignition can work at levels well past what you guys are doing.
Second off, take the pro 1's out. I am telling you that they are hurting you.
Old Dec 1, 2008 | 05:13 PM
its not me doing anything its my friend..
doesn't tony1 use the pro1's
ill try to get a graph from him
Old Dec 1, 2008 | 05:21 PM
morgan@synapse motorsport's Avatar
I bet vtec was never engaging
Old Dec 1, 2008 | 05:23 PM
maddog20's Avatar
maybe a partially collapsed Flex Section in the exhaust?
is the motor properly degree'd?
Old Dec 1, 2008 | 06:35 PM
JDogg's Avatar
werd
and with a small turbo and a log manifold pro1's will KILL your car.
just because tony1 runs em dosnt mean they will work in every setup.
put some stock b-series cams in there.. gsr, b16, itr.. anything but what you have
Old Dec 1, 2008 | 08:21 PM
pics of the graph..
the top line is tq.. in the last pic u can see hp on the left its scaled a bit diff than the tq side
sry for the bad pic its from a video
Old Dec 1, 2008 | 08:27 PM
this is not the end result tq is at about 290 in this one..
they kept adding timing and the tq kept rising , but the hp stayed the same
Old Dec 2, 2008 | 07:29 AM
JDogg's Avatar
notice that as soon as vtec comes in the curve goes to ****. cams are too big, you have too much exhaust pressure to make use of those cams.
Old Dec 2, 2008 | 08:09 AM
alpha's Avatar
That is just about what it looks like. I've had this happen with Mazworx cams, Edelbrock intake manifold, log manifold and T350 turbine wheel
Old Dec 2, 2008 | 08:25 AM
Turbo-LS's Avatar
I didnt even read any further than huge motor/cams and tiny turbo. The saw log manifold and knew the answer.
Need to put in some stock cams brother, that or get a good flowing manifold. Im going to make a safe assumption that its not even the larger inline pro but the smaller a/c friendly one. Way to much cam for that turbo and manifold combo.
Yes Tony1 rusn them with a massive turbo and a free flowing manifold along with a 4" up-pipe that is only about 12 inches long. you've got restriction out the a-ss for those cams. gsr cams will heavily compliment your setup. even type r's IMO will be to much others will feel differently on that but with that turbo gsr cams will be excellent.
Old Dec 3, 2008 | 05:32 PM
i just talked to him the cams were in fact gsr cams.. he hasent even put the pro 1's in it yer.. so what else could it be hes coming over sat for me to check timing cam gears ignition, plugs, boost leak, and a leakdown test ill post results if any
Old Dec 4, 2008 | 06:00 AM
JDogg's Avatar
does the car have a cat? if so make sure its not clogged up.. how big is the exhaust.
Old Dec 5, 2008 | 03:30 PM
3 inch open dp
im going to check everything for him tomorrow hopefully we will see some results
Old Dec 5, 2008 | 04:04 PM
ABK's Avatar
ABK
That's exactly why you street tune (at least on low boost) before going to the dyno. Just paid whole bunch of money to find out something is messed up. It looks like as soon as your turbo start spooling it shuts down. Boost leak? Wastegate acting up? What's the boost cut at? Does it sound like it's missing? Did the vtec ever kick in?
Old Dec 5, 2008 | 05:25 PM
95dxsir2's Avatar
whats the a/f look like the whole rpm range?
what are the o2's doing?
or o2
ashb82
Sep 23, 2010 12:11 PM
MTVtec
Apr 30, 2009 06:38 AM
ImPuLsIvE
May 30, 2008 10:05 AM
hdsupercrewf150
Honda S2000
34
Jun 23, 2007 07:51 PM
MooreBoost
Jun 25, 2003 05:10 PM
