just boosted now extra coolant in overflow
Old Dec 1, 2008 | 10:58 AM
user 98292739's Avatar
Default just boosted now extra coolant in overflow
ill make this short and simple
ran motor for 6 months no problems ran great
arp head studs are used about 10 times
cometic headgasket .71 or something liek that
now i am boosted on 6-8 psi (i am pretty sure its 6 my guage is off starts at 2 psi at no vacuum) greddy kit 15 g
checked coolant today second day and my over flow had extra coolant about 2 cups or what not.
could my arps be streched used to many times? or does the cometic gasket need extra tq since its so much thicker?
arps tq to 65lbs.
Old Dec 1, 2008 | 12:00 PM
bigdgsr's Avatar
Have you really re-used your ARP's 10 times? Are you overheating? What motor is this?
Old Dec 1, 2008 | 12:35 PM
MHBb16CRX's Avatar
my first guess would be blown head gasket, But need more info
Mo
Old Dec 1, 2008 | 04:41 PM
yes give or take 2 times. I had a blown headgasket problem over and over again i thought it was a timing issue. Later i found out that my sleeves has sunk. So i sent out the block ot laskey to get it rebuilt. After the rebuild i needed to get a thicker headgasket because i had piston to head contact. I ordereded the cometic .71 gasket.
tq everything down to 65 lbs (i have previously tq them down to 70lbs) im not sure why i did 65 lbs. I guess after reading over and over people just do 65 i didnt want to over tq them sicne i have snapped one arp stud before but that was human error.
anyway 2nd day of boosting look into my coolant overflow and blamo there was more then i started with. I looked under the cap and it was missing coolant in the radiator. So its been blowing out of the rad into the over flow. There are bubbles coming from the tube in the overflow which leads me to believe it is teh head gasket or that my studs have been streched too much and needs replaced.
y7 AEBS sleeved
Eagle Rods
cp pistons
head is fully built and zex 59300
Old Dec 1, 2008 | 05:13 PM
miller's Avatar
Maybe i missed it but, Did you have the car tuned?
Old Dec 1, 2008 | 06:36 PM
^yes sir i got a base map from xenocrone and then my friend fine tuned it so it runs perfect now.
Old Dec 1, 2008 | 07:48 PM
willyboyK20's Avatar
Yep your head gasket is either lifting under boost or the arp's are worn.
I don't know how you torque'd yours but when did my arp's on my y8 w/new oem hg, i did in steps following the helms manual.
Old Dec 1, 2008 | 08:09 PM
i am thinking they are worn since the problem didnt exist 6 months prior.
i did mine in steps did hand tight, 20 lb, 45 lb, 65 lb in the correct order.
i may go back and re tq them down to 70 to see if that helps if not then im going to buy new arps.
question now is can the cometic gasket be re used agian...i only ask becuase recently i have heard of people reusing their metal gaskets. if not then im out another 100+ on a custome gasket.
Old Dec 1, 2008 | 08:16 PM
AK94GSR's Avatar
i would get new studs or could try to torque them down more. you are for sure pushing coolant out from cylinder pressure
Old Dec 1, 2008 | 08:19 PM
Mike@CCT's Avatar
Formerly Mike@TSR
My best suggestion is to get new head studs.
Check the deck of the block and head with a straight edge and a feeler guage.
DO NOT re-use the headgasket.
Old Dec 2, 2008 | 05:29 AM
ya i think i am going to try this route first tq them down to 72 lbs
blah i know i shouldnt reuse the headgasekt i was just hoping i could sucks
DennisWaller
Aug 6, 2008 02:33 PM
mastakmk
May 5, 2008 10:53 AM
boostedNOTHARDLY
Dec 4, 2007 07:27 PM
ALMXDUPINTEGRA
May 11, 2005 11:05 AM
dunkd
May 20, 2004 09:46 AM
