New Turbo: Intake housing outlet faces block, can i rotate it?
Hey, my friends uncle just happened to acquire a .50 trim garrett turbo w/ HKS internal wastegate. He said he would sell it to me for 200-250 ish, does that seem like a good deal??
the only thing is the intake housing outlet faces towards the block, can i take the bolts off the intake housing and rotate it to where i need it?
you mean the outlet faces your block
you loosen teh 1/2 ( or 13mm works too) nuts on the compressor housing and the turbine housing and you can clock/rotate the housings to where you need the compressor outlet to be and the feed/return. research online " clock turbo"
