Sleeving a block
Old Sep 9, 2002 | 07:07 AM
FOrSfEd's Avatar
Default Sleeving a block
I'm just thinking if it is really worth sleeving a block if I'm only gonna be running under 11psi on a crvtec with a built bottom end, I figure if I wanted to sleeve a block I should have bought a b18b and used 84mm pistons to build it. I will be running a hondata 2b ecu fully tuned so hopefully everything will be running nicely.
What does everyone think about this.
Lee
Old Sep 9, 2002 | 07:16 AM
ekb18c's Avatar
Default Re: Sleeving a block (Rex2nv)
Get it sleeved, your going want to increase the boost later.
Trust me! You will want to boost higher later on.
Boost is like the worst drug you can think of !!
If you have a spare block then sent out the spare bock to get it sleeved, that way your downtime won't be that great.
Old Sep 9, 2002 | 07:23 AM
autoEXturbo's Avatar
sleeve it, you sleeve it and 20+psi will be your best friend.
Old Sep 9, 2002 | 07:36 AM
FOrSfEd's Avatar
Default Re: Sleeving a block (autoEXturbo)
See i was thinking of doing it but, on a crvtec you really don't have to boost up real high to make good horsepower. I figure I can make and easy 325+ with a crvtec built bottom end with a t3/t4 turbo ar .50, 550 injectors, walbro 255 fule pump and a hondata 2b for engine management. I don't know I prob we go ahead and do it but I still am not completeky sure.
Lee
Old Sep 9, 2002 | 07:43 AM
I know you can make some insane power out of that motor with low boost so sleeving the block in the sense of using more boost to make that power isn't really needed. Personally i would sleeve the block just to have the security of knowing that it will handle what you throw at it.
Old Sep 9, 2002 | 07:45 AM
FOrSfEd's Avatar
Yeah that is a very good point and one I am really taking into consideration, thanks alot for the input keep it coming.
Lee
Old Sep 9, 2002 | 07:51 AM
yea that was my one concern, i knew the gsr could handle some boost, but i needed to know that when i up it, that the block will hold the boost. Well you replied to my post so there is a ton oh stuff that i'm doing, but whatever can be done to make it safe, i'm doing.
Old Sep 9, 2002 | 07:54 AM
FOrSfEd's Avatar
I figure you just go back to the old saying, better safe than sorry.
Lee
silver95lsboosted
Sep 18, 2007 07:02 PM
Boostin_GSR
Apr 4, 2007 12:21 AM
tobe1424
Aug 16, 2005 10:11 AM
aut0tek
Apr 2, 2003 02:50 AM
B18CHatch
Oct 18, 2001 03:06 PM
