... vafc hack with 550's
Old Sep 9, 2002 | 05:19 PM
1.8T_EG's Avatar
Default ... vafc hack with 550's
... has anyone ever tried the hack with a set of 550 injectors?... will this work?... also, any guesses for settings?... lemme know... thanks...
Old Sep 10, 2002 | 06:19 AM
1.8T_EG's Avatar
Default Re: ... vafc hack with 550's (1.8T_EG)
... does anyone have the flow ratings for stock second gen rx7 injectors?... i was told that they are 550 but i am not sure... also will this work with the vafc... thanks...
Old Sep 10, 2002 | 06:20 AM
GraphiteAccord's Avatar
from my understanding, it was ethier the v-afc or the ecu could only handle up to 450cc injectors....
Old Sep 10, 2002 | 08:47 AM
Smashback's Avatar
Default Re: ... vafc hack with 550's (GraphiteAccord)
You can use 550's but it will run very rich. You'll also need an adjustable FPR to lean it out, but I'm sure it will still run very rich.
Old Sep 10, 2002 | 10:42 AM
filetofit
Guest
Posts: n/a
The consensus on this board seems to be a -35% cut in MAP sensor output voltage with the VAFC hack and 450cc injectors. That still leaves you with substantial room to compensate for 550cc injectors since the VAFC goes to -50%.
I' say try
(1 - 240/550) x 12.5 /14.7 = -48%
and a little less of a cut at idle (-40 to -45%)
Old Sep 10, 2002 | 10:56 AM
1.8T_EG's Avatar
Default Re: ... vafc hack with 550's (filetofit)
... that is exactly what i was thinking... now, with a higher correction factor, does that allow me to run higher boost?... say in the 12-14 psi range?... also, how much will the larger injectors be a concern since they will take longer to open?... thanks...
Old Sep 10, 2002 | 01:52 PM
filetofit
Guest
Posts: n/a
Yes with larger injectors you should be able to run more boost.
(3.0 volts x 0.52)/15 psi = 0.104 volts per psi
2 volts / 0.104 volts per psi = 19 psi boost,
One of the downfalls of the hack though is it leaves the issue of boost timing retard unaddressed. Since you'll be using stock timing, at high boost you'll be running a lot of advance. You need some way of dialing out the advance.
You'll need to use a smaller cut in MAP voltage at idle to compensate for the larger injectors opening time. Hondata recommends adding back 30% pulsewidth at idle after applying the injector multiplier. Hard to say what that corresponds to in terms of MAP voltage cut.
http://www.hondata.com/techinjectorsizing.html
Old Sep 10, 2002 | 02:45 PM
liam821's Avatar
25 Year Member
To get around the timing..just run race gas! Full timing at high boost baby.
I was playing around with my car..i turned up the fuel pressure, and down the afc to -45%. The car ran awesome in boost..but idling and normal driving was pretty ruff. It did work though. I lowed the fuel pressure back down and have my afc at -40% and it works much better. My idle is set at -30%.
liam
Old Sep 10, 2002 | 02:59 PM
turboedef9's Avatar
Default Re: ... vafc hack with 550's (liam821)
well i have been running the hack since may when i put my turbo in and it seems to work ok but it isnt good past 7-8 psi on my car. granted im runnig a b16 so it will require more fuel but i am using an fmu with an 8:1 in it. i have my lowest setting at -35% and my max is -32%. i tried to run 10 psi but it leaned out and started poping. i do have an msd 6btm set at .5 degrees retarded so i dont think it was the timing but i do know that it leaned out so im going to fix that by running my check valves and set the fuel at -25% or somewere in that range. the hack is an awsome idea in it works great i have used it all summer with little problem and all my friends are shocked at how it works ...i love when someone with a 92 and up civic or 94 and up integra asks me if they can run it to and i tell em no ... then i tell them to get the resistor pack nd they say o hell no..at least us old school guys have something that the newer cars dont have without alot of work.
Old Sep 16, 2002 | 12:16 PM
1.8T_EG's Avatar
Default Re: ... vafc hack with 550's (turboedef9)
Old Sep 16, 2002 | 12:22 PM
Smashback's Avatar
The idea of the AFC hack is that you don't need an FMU. If I understand you you are using big injectors, an AFC and an 8:1 FMU. So first you'd need a massive fuel pump for that....high pressure and high volume. If you have a good pump, and you're using it like you say, you are probably running WAY rich. I don't know the full details of your setup but it sounds like you'd be running rich rather than lean.
tur3oDC4
Nov 27, 2004 07:21 AM
Griffin@Camtech
Feb 6, 2004 10:31 AM
1.8T_EG
Dec 9, 2003 09:11 PM
Nextelbuddy
Dec 5, 2003 05:35 PM
aemciv
Feb 26, 2003 11:31 AM
