finally figured it out-new times!
Old Sep 7, 2002 | 05:07 PM
turbotypeR@SPEC's Avatar
25 Year Member
Default finally figured it out-new times!(gsr cams rule!)
i finally switched to gsr cams and all i can say is wow!last night we went to montgomery for some test and tune and i ran 3 times-12.08 @117,12.10@121and12.05@119.it had absolutely no traction through first and second gear.i tried lowering tire pressure to 10 lbs and launching on low boost and it was still blowing the tires off.the track was not prepped and all of the street cars were doing burnouts all the way through the lights.also,i didn't have real good gas so i had to keep the boost down to about 20 lbs.i am so excited because now i know it will run 11's.with a properly prepped track,some practice,and some good gas i think we can go deep in the 11's.
[Modified by turbotypeR, 8:15 PM 9/7/2002]
Old Sep 7, 2002 | 07:53 PM
rondigs's Avatar
Default Re: finally figured it out-new times!(gsr cams rule!) (turbotypeR)
I'll be the first to say...congrats.
Old Sep 7, 2002 | 08:26 PM
Quick 200k Mile Motor's Avatar
which generation ITR cams did you have before the gsr cams?
What difference did you notice? did you dial out overlap?
Old Sep 7, 2002 | 11:59 PM
shadowdawn's Avatar
Default Re: finally figured it out-new times!(gsr cams rule!) (Quick 200k Mile Motor)
Jesus christ :D
Old Sep 8, 2002 | 05:37 AM
speedworks's Avatar
Default Re: finally figured it out-new times!(gsr cams rule!) (shadowdawn)
thumbs up. youll soon be in the 11 second club
Old Sep 8, 2002 | 06:43 AM
DRAGLS's Avatar
Default Re: finally figured it out-new times!(gsr cams rule!) (speedworks)
what's the setup? full details.
Old Sep 8, 2002 | 07:45 AM
25 Year Member
Default Re: finally figured it out-new times!(gsr cams rule!) (DRAGLS)
they were 97 itr cams.as far as the set-up goes,here's a quick run down.golden eagle sleeves,je pistons,crower rods,custom turbo setup,venom 100gph fuel pump,720cc injectors and power fc.i did dial out overlap-+4 exhaust,-2intake.taking in consideration for how far off the cam gears are(head milled and block decked twice),it is really only +2 exhaust.i haven't done any tuning on the dyno since the cams but after some cam tuning on the interstate,it will absolutely blow the tires off at 80 mph!
Old Sep 8, 2002 | 01:48 PM
TurboTegB18c's Avatar
Congrat danny, hope to see you oct 5 in montgomery. Paul
Old Sep 8, 2002 | 02:15 PM
quikB18B's Avatar
Default Re: finally figured it out-new times!(gsr cams rule!) (TurboD16Z6)
Theres something i love about turbo R's, but yours since its a 97 makes it that much better. Congrats on a nice car and setup. Be nice to it
Old Sep 8, 2002 | 03:26 PM
ski_rebel_3's Avatar
Default Re: finally figured it out-new times!(gsr cams rule!) (quikb20)
Congrats!! I agree with you..11's are not out of your reach...good luck!
Old Sep 9, 2002 | 04:49 PM
25 Year Member
i'm trying to picture who you are paul,give me a hint.and what is going on on the 5th of october?
Old Sep 9, 2002 | 05:07 PM
paulzy's Avatar
congrats
Old Sep 9, 2002 | 06:04 PM
Teg4e's Avatar
What's your wheel/tire combo?
Old Sep 9, 2002 | 06:14 PM
hybrid901's Avatar
Default Re: finally figured it out-new times!(gsr cams rule!) (Teg4e)
Thats some badass mph
Old Sep 9, 2002 | 06:17 PM
FBP Si 2000's Avatar
Congrats
Old Sep 9, 2002 | 06:20 PM
RATEDR's Avatar
SWEET!
Old Sep 9, 2002 | 06:53 PM
This is paul from montgomery, the asian guy lol, the one that talked to you at reynolds, remember the race on oct 5 at montgomery track, open by one of the stereo places. Remember??????
Old Sep 9, 2002 | 08:44 PM
biassj's Avatar
Nice!! I would invest in 26' slicks....
Old Sep 10, 2002 | 04:52 PM
25 Year Member
15x8 bogarts with 24x9.5x15 and they do rub,so a bigger slick is out of the question.
Old Sep 10, 2002 | 04:56 PM
25 Year Member
sorry dude.i thought that was you but i saw your profile had pensacola florida.i thought you lived in montgomery?i forgot all about that race.they don't have it on there web page or anything.and they wonder why they never have a turn out.i plan on being there anyway.
Old Sep 10, 2002 | 07:59 PM
Danger's Avatar
congrats on the times man !! good **** . im in the process of building up a 98 ITR motor for my integra . you have givin me sumthing to look forward to . wat compression are you at ?
Old Sep 11, 2002 | 04:59 AM
25 Year Member
Default Re: finally figured it out-new times!(gsr cams rule!) (jonny5)
9:0 to1 compression.just so you know ,go ahead and get gsr cams.i went forever without themand the car loves them.
Old Sep 11, 2002 | 05:46 AM
PM-Performance's Avatar
nice ******* time man.
ill be there with you soon .
check your pm i got a question for you
Old Sep 11, 2002 | 06:17 AM
jinxproof99's Avatar
New User
Default Re: finally figured it out-new times!(gsr cams rule!) (itr206)
stick with your 24" tires. lower your tire pressure to about 7 psi. launch @ around 8000 rpms. start from there and play with the tire pressure and launch. 119 mph is easy 11's, even in your type r. you'll get it.
Old Sep 11, 2002 | 09:06 AM
sleepercivic's Avatar
Default Re: finally figured it out-new times!(gsr cams rule!) (jinxproof99)
what type of suspension setup do you have, traction bars, poly bushings, coilovers?? i need help because i would like to hit low 13s high 12s on street tires
TERRY
