440cc injectors, is a 180lph pump big enough???
I have a D16Z6 with a t3 turbo and some 450cc injectors, i have just obtained a 180lph MR2 turbo fuel pump, will this flow enough fuel to run upto 10psi??
I have a S-AFC to control the fuelling but do i need a bigger pump?? what spec is the standard civic pump??
thanks
PAul
thanks
PAul
Re: 440cc injectors, is a 180lph pump big enough??? (DLB1994)
well i can run the hack or a FMU cos i have both a 12:1 FMU and a S-AFC but what i need to know is if the following pump is good enough to run 45occ injectors up to 10psi
PUMP SPEC= 180lph @ 43psi @ 12v
225lph @ 43psi @14v
225lph @ 43psi @14v
Re: 440cc injectors, is a 180lph pump big enough??? (deacs)
You cant run an fmu on that pump, it will crap out on you before you reach 90psi or more which you will be doing with a 12:1 fmu. Just use the afc and injectors and thats it.
Re: 440cc injectors, is a 180lph pump big enough??? (shadowdawn)
yeah i understand that i dont need to use the FMU but once again what i actually need to know is will a 180plh pump be good enough to use with 450cc's and a SFC hack??
I ask because evryone seems toi have 255lph pumps, so i want to know if a 180lph pumps is up to the job
thanks
thanks
Shouldn't be a problem but if you want Viren is having a groupbuy on walbro 255lhp pumps up until this wednsday, I'm assuming a 180lph is bigger then stock? Cause right now all I'm using is stock pump with afc hack at 7 psi and I'm rich as *****.
KevronsEG
08-05-2002 08:29 PM
