hondata with VAFC and 02 simulator question ???
Old Sep 9, 2002 | 05:34 AM
GOKOU's Avatar
Default hondata with VAFC and 02 simulator question ???
When using hondata can a VAFC still be connected to read rpm, intake pressure, throttle? Does the 02 simulator used for straight pipe need to be taken out when using hondata?
Thanks
Old Sep 9, 2002 | 06:15 AM
Firedrake's Avatar
Default Re: hondata with VAFC and 02 simulator question ??? (GOKOU)
Yeah, of course.....I did this just yesterday.....just remember that VTEC will switch wherever you have it set on the VAFC, and not the hondata....we were out tuning and suddenly remembered this
For part 2 I'm assuming you're OBD2 if you have an O2 in the cat......hondata requires OBD1 conversion, so you wouldn't be using that 2nd O2 anyways.....so you can leave it in or out, it won't affect anything either way
Brian
Old Sep 9, 2002 | 09:22 AM
GOKOU's Avatar
Default Re: hondata with VAFC and 02 simulator question ??? (Firedrake)
Thanks. You're saying that I do not have to disconnect any wires of the VAFC? I thought I had to reconnect the VTM signal, VTEC signal and Pressure signal back. I guess I'll be leaving in the VAFC to monitor RPM, throttle, and intake pressure then.
[Modified by GOKOU, 6:34 PM 9/9/2002]
Old Sep 9, 2002 | 09:48 AM
Firedrake's Avatar
Nope you can leave all those the way they are......thing is, they pass through the VAFC so it can alter the values if necessary to engage VTEC whenever you have it set......when you finally go all hondata though, I'd just take the VAFC out (that's what I did).....
BRian
JFG Kevin
16
Jul 13, 2006 05:56 AM
nuezdaman44
May 18, 2006 12:23 PM
lopey
Nov 12, 2005 05:38 AM
tub_sephiroth
Dec 5, 2004 07:53 PM
daddymaxx
Nov 21, 2003 12:44 PM
