Feasability of running a JRSC with 12.5:1 CR...?
I currently have 12.5:1 .020 over JE pistons with eagle rods and stock sleeves in my JDM GSR block and a stock head. Now, ive always liked superchargers but unfortunantly made the high CR decision before i had thought it thru completely.
My question is how likely is it to get a safe running JRSC at 6 or 8psi with 12.5:1 CR? I have access to 110 octance race gas, 104 octane race gas and 94 pump gas.
Any input would be great. Thanks!
-Nick-
-Nick-
Re: Feasability of running a JRSC with 12.5:1 CR...? (B19CivicHB)
with that high of compression you have very little room for error. i would not recommend running this type set up personally, but if you have it dyno tuned properly with a good engine management system anything is possible... And i seriously doubt you want to pay to run 104 octane 24-7. did you guys know that the big 18 wheeler's run turbo diesel with 18.0:1 compression? Pretty crazy huh... dont think im trying to relate the 2, just thought id share that with everyone.
Re: Feasability of running a JRSC with 12.5:1 CR...? (GudeH23a)
yea most turbo diesels run extremely high compression ratios. probably because they run different fuel and run glow plugs instead for spark plugs.
Re: Feasability of running a JRSC with 12.5:1 CR...? (BoostedH23a1)
alright, i guess the JRSC is out of the question for this engine... thanks guys.
Diesel engines as you guys know are way different as our unleaded engines combust, diesel detonates,detonation is a diesels friend. Its how they run. There are guys that I have seen up the boost to close to 30psi on a diesel truck, no worries pretty much. With ur high of compression is it possible to change the headgasket to lower the compression a little? Not sure if it would help enough but just curious.
Good luck!
mike
Good luck!
mike
Re: Feasability of running a JRSC with 12.5:1 CR...? (MikeMAN)
I think im just going to keep this motor NA and build my next engine for a JRSC. Thanks again,
-Nick-
-Nick-
