WG adjustment and boost ?
i have a crappy deltagate wg on my integra and I was wondering, before I start the car up for the first time with the turbo, how will i know what the wg is set on?
i have an electronic boost controller, but i'm not going to put it in for a little bit. how do i make sure it's at 7 psi or whatever before i start the car?
You can back the spring out as far as it'll go if you want to start out on a lower boost level. Deltagates are usually adjustable to about 2-3 lbs. So you may only see 4-5lbs of boost with the spring backed out, and 6-7 with it all the way in.
pip9
Sep 24, 2004 09:17 AM
accordfreak
Dec 25, 2001 12:20 AM
