HELP! Boosted B16 running lean?
Old Sep 7, 2002 | 07:12 AM
NXAccordTO4B's Avatar
Default HELP! Boosted B16 running lean?
Help guys i trying to figure out why my car is running lean after about 5 mins of running. This is what I got on my 92 Civic HB:
greddy turbo
VAFC
AVCR
RC 450cc
AEM fuel rail
AEM pressure reg.
MSD 6al
p28 ecu
and all your other basic parts.
however, this is what happens. I would start the car, my AF meter would show rich. After boost @ 5psi for about 5 mins or so. The meter would stay around the red zone. Timing is good. however car idle a little rough. thanks for the replys
Old Sep 7, 2002 | 08:15 AM
Mr. Vapor's Avatar
Default Re: HELP! Boosted B16 running lean? (NXAccordTO4B)
idle is rough most likely due to the large injectors.....310s or 370s would probably suit you much better.
also since you are running since large injectors its possible that you are putting so much fuel through that you fouled out your 02 sensor and now its reading lean.
just a few thoughts
Old Sep 7, 2002 | 08:19 AM
doughboy247's Avatar
Default Re: HELP! Boosted B16 running lean? (NYb16)
i will second that! BAD 02's! or maybe you need to richen your settings on the afc.
1baddcivicsi
Oct 29, 2006 08:26 AM
mikeunreal2
29
Mar 22, 2006 06:26 PM
themaskdmumbler
Mar 12, 2006 07:06 PM
JDM KING
14
Sep 20, 2004 10:59 PM
NXAccordTO4B
Sep 7, 2002 08:39 AM
