Greddy Oil Catch Can
Old 09-06-2002, 11:17 PM
MugenGTR's Avatar
Default Greddy Oil Catch Can
how do u install the clear view tube? i know u screw in the 90 degree thingies but how do u get the clear tube to stick on to that? and, how did u mount it? i mount the brackets but came w/ no screws. would double sided tape work?
Old 09-08-2002, 12:03 AM
PrecisionH23a's Avatar
Default Re: Greddy Oil Catch Can (MugenGTR)
one tube goes from your intake manifold (the one that runs to the pcv valve) on your intake manifold, the other goes on the PCV valve thats on the valve cover, thats how my h23a one is. or you can just run one hose from your breather on the valve cover then put a breather on the open port on the catch can if you dont feel like running 2 lines. if you need more hose you can get it at either lowe's or home depot in the plumbing section, they only have standard sizes so get the one closest to what you have now.
type B16
09-24-2006 04:14 PM
crxsiperf
06-01-2005 11:03 PM
Grip
06-15-2004 05:43 AM
TurboB18C1
01-10-2004 10:26 PM
KekeK-18
07-12-2001 05:17 PM
Quick Reply: Greddy Oil Catch Can
