factory turbos and wastegates
Old Sep 9, 2002 | 01:33 PM
2000si's Avatar
Default factory turbos and wastegates
u always hear about people selling turbos off of vovlos or saabs and they have an internal wastegate. i heard that an external wastegate are better. is there any way to convert an internal wastegate turbo to an external wastegate turbo. also what is the difference between a factory turbo and an aftermarket turbo like the ones that come in the drag, fmax, etc... kits.
thanks
Old Sep 9, 2002 | 01:36 PM
GraphiteAccord's Avatar
Default Re: factory turbos and wastegates (2000si)
well, and "aftermarket" turbo can be sized to whatever you want, while one pulled off a car is just what was made for that car, not a civic etc. External gates are better in some ways, and yes, an internally gated turbo can be disabled for use with an external gate.
Old Sep 9, 2002 | 01:44 PM
blufke's Avatar
Default Re: factory turbos and wastegates (GraphiteAccord)
how can you disable the internal?
Old Sep 10, 2002 | 08:01 AM
2000si's Avatar
Default Re: factory turbos and wastegates (blufke)
is there a website or anything that will tell you how to turn an internally gate turbo to an externally gated turbo. anyone have any instructions
Old Sep 10, 2002 | 09:58 AM
DeepSi's Avatar
I think it is somewhere on this website, but i am not sure, and do not fill like searching it. http://homemadeturbo.com/
hope this helps
-deepsi
Old Sep 10, 2002 | 10:50 AM
M.A.R.C.'s Avatar
Default Re: factory turbos and wastegates (DeepSi)
depends on which turbo you have and which car it came off. My t3 was converted to external wastegate by just taking off the wastegate actuator and the flapper assembly on the turbine outlet (it was like a downpipe flange with the flapper assembly built in). Other turbos u can take the actuator off and weld the flapper shut
olddohc
Jul 29, 2007 11:14 PM
Dan_the_MaN
Oct 5, 2005 12:08 AM
