Hondata turbo setup
Old Sep 9, 2002 | 10:41 AM
I Like Boost's Avatar
Default Hondata turbo setup
97 gsr built engine
running a hondata 2b
want to boost 1 bar (14 psi)
what size rc injectors should i get
and what else do i need to run the correct fuel setup?
Old Sep 9, 2002 | 10:54 AM
FredoSP's Avatar
Default Re: Hondata turbo setup (BEe18SeAONe)
Walbro 255lph, B18Bturbo is having a group buy, pick one up if you want. Maybe 550cc injectors with a resistor box. That's all I can think of, anyone else?
Old Sep 9, 2002 | 10:58 AM
Default Re: Hondata turbo setup (FredoSP)
thanx for the reply,
ya i was thinking 550cc injectors also.
for the pump is that an in-tank or in-line?
where can i get a resistor box? and how much?
anyone else......
b18bturbo's Avatar
your right 550cc or 55lb injectors should work just right..
Old Sep 9, 2002 | 11:05 AM
Finest's Avatar
Default Re: Hondata turbo setup (b18bturbo)
Do you really need the resistor box if you're running a Hondata?
Old Sep 9, 2002 | 11:35 AM
Dutchie's Avatar
Default Re: Hondata turbo setup (Prelude_RCR)
I would think so because Hondata still uses the stock drivers.
Old Sep 9, 2002 | 11:38 AM
Firedrake's Avatar
Our stock motor B18C 'teg boosting around 1 bar at stock fuel pressure and 255lph HP walbro never got above 78% duty cycle on DSM 450cc's.......so if you're ever planning more than 14lbs (which I assume you are on a built motor) you'll probably want 530's or more.....
FYI, the JDM 4G63's came with like 530cc's, so if you can find a DSMer who bought one of those motors you can probably get 530's for like 70 bux
Brian
Old Sep 9, 2002 | 11:48 AM
philo's Avatar
Hondata and AEM both require a resistor box for low impedance injectors. I just did a hondata install with 720's and the car ran perfectly. If you are going to do the whole resitor box thing I would save yourself some hassle later and go with 720's.
Old Sep 9, 2002 | 11:49 AM
Default Re: Hondata turbo setup (Firedrake)
thanx guys,
im gonna be running 14 psi max (track days or big street races) 5% of the time.
probley around 8-10 psi on the street. 95% of the time.
so do u think the 450cc's 550cc's or 720cc's??
any other comments / suggestions??
turbo and most parts are from a drag gen 3 kit
[Modified by BEe18SeAONe, 3:50 PM 9/9/2002]
[Modified by BEe18SeAONe, 3:52 PM 9/9/2002]
Old Sep 9, 2002 | 11:51 AM
sgT's Avatar
sgT
turbo size will play a large part on the fuel requirements.
Old Sep 9, 2002 | 12:01 PM
VaporTrail's Avatar
New User
Default Re: Hondata turbo setup (sgT)
yeap. I'd recommend 550's if you are sure 1 bar is all you are going to run. If not sure, go up to 660s or 760's. They both work fine with Hondata.
Old Sep 9, 2002 | 12:06 PM
Default Re: Hondata turbo setup (VaporTrail)
thanks again for all the replys
im gonna go with the 550cc's with the walbro pump
am i gonna need a fuel pressure regulator for tuneing?
also where can i get the resister box from?
Old Sep 9, 2002 | 12:12 PM
VaporTrail's Avatar
New User
you won't need a regulator. I've made nearly 450hp without touching it.
You can get the resistor box from
90-91 Integras
88-91 CRX Si and HF
92-96 Prelude
90-97 Accord
88-89 Integra
and probably a few more I'm missing.
r1ch1e
Sep 11, 2006 07:58 PM
Diego Boost
Feb 26, 2003 11:10 AM
Sprockets
Dec 21, 2002 12:56 PM
civcexcoupeblack
Dec 16, 2002 01:16 PM
kuya kanin
Oct 2, 2002 06:28 PM
