HELP!!!!
Old Sep 8, 2002 | 06:54 PM
its WANG yoO's Avatar
Default HELP!!!!
ok...
i've been having problems with my turbo LS...
i changed the head gasket...and my turbo is spitting oil into the down pipe...i did a compression test...and here are the results:
#1 120lbs
#2 180lbs
#3 165lbs
#4 160lbs
so something is wrong with cylinder #1....would a cracked ring or piston be my oil backing up in the turbo problem??? also...when i take off the oil fill cap...light blue smoke comes out...also when i take out the PCV valve...the same happens...can this all be caused by a cracked piston or ring??? in cylinder #1???
Old Sep 8, 2002 | 07:10 PM
DIRep972's Avatar
Smarter than you
Default Re: HELP!!!! (hybridRhatch)
yep, its gone man. gonna have to rebuild it now or at least put in new pistons and hone it. how much boost were u running?
Old Sep 8, 2002 | 08:05 PM
Default Re: HELP!!!! (DIRep972)
i was running around 14lbs...i believe...i had no gauge and my Hondata shuts off at 15psi..so i was around that prolly...hehehe...i'll learn i guess...plus the motor had it fair share of beating on it...
so is the turbo good?
Old Sep 8, 2002 | 08:17 PM
LsTurbo91's Avatar
good sense of humor is the way to survive this game and lots of money
Old Sep 8, 2002 | 08:31 PM
Flamenco-T's Avatar
Default Re: HELP!!!! (LsTurbo91)
your turbo is prolly have blown seals, that is the reason why you're spitting oil, alhtough bad rings can cause it as well...
take your car for a spin, and have someone follow you...a smoke while accelrating is def a crack rings/ringlands...
but from the way you describe it, yes, you prolly toasted your rings....
stan
Old Sep 8, 2002 | 09:04 PM
Default Re: HELP!!!! (Flamenco-NA)
the car smokes when you rev it...and i did a compression test...#1 cylinder has 120lbs...so i know its the rings...but will rings being bad make the oil back up in my turbo???
Old Sep 8, 2002 | 11:31 PM
ion_four's Avatar
stan
it wouldn't be the turbo...he said he has smoke coming out of the valvecover (oil-filler cap) and the pcv valve grommet...has to be the rings/pistons...
BTW, why did you change your headgasket? Could it possibly be that you really fucked that up?
Old Sep 9, 2002 | 06:03 AM
Default Re: HELP!!!! (ion_four)
nah..head gasket is fine...doesn't loose any antifreeze and it smokes blue...NOT...white...and i changed the head gasket cuz it WAS smoking white and puttin antifreeze out my downpipe and turbo...
all i was asking is if a BLOWN piston or rings would make oil backup in my turbo...would i not let the oil return back to the oil pan...thats all i need to know..thanks alot for all your help guys!
myessay
Jan 27, 2012 01:59 AM
Scheizty
Feb 18, 2009 03:21 PM
b18b12hatch
Jun 2, 2006 08:16 PM
filetofit
Aug 13, 2002 10:45 AM
