should i go hybrid turbo?
New User
i have a stock B18C in my hatch and found a T3/04e Turbo kit for $3400. I was planning on going NA (becasue i got B18C) but i can be in the 11's with this setup. If i don't go turbo i will go with JUN 3 cams. I will be doing the install by myself so there is no cost to install.
any opinions? thanks.
Re: should i go hybrid turbo? (B18C-Hatch)
Well it totoally depends on what you want, but if you want opinions I would go turbo. The power you get from a turbo is alot easier and cheaper than you could ever get from a NA setup.
although, in order for you to get into the 11's you'll need a built bottem end so you can run more than about 9 psi.
plus the sweetest sound in the world is the snail spooling up and if you couple that with a kickass bov then you are in heavan.
gl with your desicion
