Having trouble starting new motor....
Re: Having trouble starting new motor.... (Projekt20)
Battery, ECU, distributor, wires, spark plugs, fuel pump, injectors, regulator, MAP sensor, IACV sensor, gas in the tank...
Wow I am *drunk*. I think my checklist makes sense, don't it?
Re: Having trouble starting new motor.... (paul_vang)
It cranks....but it just won't turn over. I know fuel is getting in there cause I smell a hint of it in the bay. No spark maybe? Louis have a few shots of 99 Bananas on me and go 2 sleep.
-Trung
-Trung
New User
Just pull a plug wire off the end of the cap and hold it like an inch away and see if you are getting spark. If you are, then that could be a compression problem. Just break out the gauge if you are getting spark, if not, try to figure out why you arent firing. Good luck
