JB weld question
Old Sep 8, 2002 | 11:48 AM
HondaCutter's Avatar
Default JB weld question
I'm about to install my drag turbo kit, I was wondering if I could use JB weld for the oil return pipe going into the oil pan? Will the JB weld hold up? has anyone else done this before? Thanks in advance.
p.s. I did a search and could not find anything.
Old Sep 8, 2002 | 11:56 AM
FBP Si 2000's Avatar
Default Re: JB weld question (HondaCutter)
I've done it...10 months now...no leaks yet...
speedymon's Avatar
Default Re: JB weld question (FBP Si 2000)
boostin 1 week. no leaks!
Old Sep 8, 2002 | 11:57 AM
Default Re: JB weld question (speedymon)
cool, thanks
Old Sep 8, 2002 | 12:12 PM
SiR Kid's Avatar
New User
I drilled a hole in the pan and used a garden hose style bulkhead fitting on mine. Never leaked in 2 years, and I jsut changed the oil pan because of a hole from bottoming out, and I jsut put new Nylon 0 rings on it. Should be good
Old Sep 8, 2002 | 07:00 PM
LEON's Avatar
Default Re: JB weld question (SiR Kid)
a year and a half now with no problems... works great!
Old Sep 8, 2002 | 07:04 PM
Accord94DX's Avatar
how is this exactly setup? Bulkhead fittings with JB weld?
Old Sep 8, 2002 | 07:21 PM
accordfreak's Avatar
Default Re: JB weld question (Accord94dx)
in this thread for an update
Old Sep 9, 2002 | 11:14 PM
quickspoolin's Avatar
Yeah, I've always thought about using that but couldn't find one with a 90 degree bend.
Old Sep 10, 2002 | 05:29 AM
zojirushi's Avatar
Default Re: JB weld question (quickspoolin)
Mines holding up good as well. Word of advice, don't be afriad to put some of the jb weld on the inside of the oil pan. I made that mistake and oil would leak out. I had to remove the oil pan again to fix it. What a pita. good luck!
Old Sep 10, 2002 | 08:39 AM
Holden's Avatar
I've had a hole in my intake manifold (hole goes to coolant passage) plugged up for almost three years now with JBWeld.
delslow45
Apr 3, 2011 07:14 PM
labtec
May 3, 2007 10:53 AM
a1320addict
Jul 6, 2005 10:30 AM
Hyaboosta
Jan 24, 2005 02:21 PM
RedStarGsr
Dec 25, 2003 10:21 PM
