PLEASE HELP!!!!!!!!!!!!!!!!!!!!
Old Sep 8, 2002 | 12:45 AM
its WANG yoO's Avatar
Default PLEASE HELP!!!!!!!!!!!!!!!!!!!!
ok...big problem...
i just replaced my head gasket...it was blown...and i also rebuilt my turbo...2 days ago...the car smokes really bad..so bad you can't see behind you at all...the motor holds antifreeze...level in the radiator doesn't move at all...so it isn't that
i took the wastegate and downpipe off..and start the car...doesn't smoke(since missing the wastegate..turbo doesn't spool)...put those back on..car smokes really bad...all of my lines(sending and return...are both not kinked or leaking)the oil is backing up in the turbo...car spools madd hard though...just as it did before all of this ****...just smokes really bad...what is going on??? did the guy who rebuilt my turbo...**** it up? someone please help!!!
Old Sep 8, 2002 | 12:52 AM
VaporTrail's Avatar
New User
Default Re: PLEASE HELP!!!!!!!!!!!!!!!!!!!! (hybridRhatch)
sounds like bad oil seals in the turbo
but
I would run it for a while to make sure any residual crap burns off. Shouldnt be more than 20 minutes run time to do that.
Old Sep 8, 2002 | 12:57 AM
Default Re: PLEASE HELP!!!!!!!!!!!!!!!!!!!! (VaporTrail)
i just had the turbo completely rebuilt....and i let the car run for atleast 30mins and i drove it too...
boosted it and all...it boosted like it did before all this **** happened...
Old Sep 8, 2002 | 01:05 AM
Kamin's Avatar
looks like whoever rebuilt it fucked up or lied.
Old Sep 8, 2002 | 01:09 AM
Default Re: PLEASE HELP!!!!!!!!!!!!!!!!!!!! (KAMiN)
or could the turbo be warped???...i don't know what to do
Old Sep 8, 2002 | 01:13 AM
Kamin's Avatar
warped? i dont think so
it sounds like there is a blown oil seal in it.
talk to whoever rebuilt it.
Old Sep 8, 2002 | 01:19 AM
i just don't wanna buy a new turbo...is it possible to put the rebuild kit in wrong?
Old Sep 8, 2002 | 04:39 AM
turbo Si's Avatar
Take off the intake pipe that connects to the filter and see if theres oil around the lip of the turbo?
Old Sep 8, 2002 | 08:32 AM
Default Re: PLEASE HELP!!!!!!!!!!!!!!!!!!!! (turbo Si)
there isn't any oil on that side its just on the exhaust side
Old Sep 8, 2002 | 08:52 AM
DLB1994's Avatar
pull your oil cap and see if any smoke come out
if u got to much crank case psi the return line wont drain
Old Sep 8, 2002 | 09:51 AM
PrecisionH23a's Avatar
Default Re: PLEASE HELP!!!!!!!!!!!!!!!!!!!! (DLB1994)
i assume the car did not smoke before the turbo was rebuilt, correct? which company did you send the turbo to for the rebuild? it definetely sounds like your oil seal is fucked up on the turbo if you are puffing out tons of smoke, this happened to me and i filled the whole intersection up with white smoke. i also had oil all inside of the downpipe as well as over the exhaust housing of the turbo as well as on the downpipe.
Old Sep 8, 2002 | 10:16 AM
DLB...
i pulled my oil cap with the car running...there is some smoke..not a whole lot(but then again...the car wasn't really warmed up yet...so that could be why)...but there is quite a bit of pressure... it kinda pushed the oil cap in my hand when i took it off....if there is to much pressure...how do i solve it? or psi for that matter?
Old Sep 8, 2002 | 10:19 AM
turbo Si...
the car did smoke before and was using alot of oil...so i got it rebuilt...the turbo..and it still does it...i think the guy fucked up the rebuild or it has something to do with the crank case psi..like DLB said...
DLB...
my car isn't using oil either...i let it run for like an hour last night alittle today...and the motor is still full of oil...but i have a small leak in my downpipe...so there is oil dripping out of that leak.......what is going on???
Old Sep 8, 2002 | 10:55 AM
HELP!!!!!
Old Sep 8, 2002 | 10:59 AM
sutrusu's Avatar
YOUR SEALS. like 10 people have told you that. listen to them and stop asking. take it back to the shop and make them fix it.
Old Sep 8, 2002 | 11:10 AM
DLB1994's Avatar
Default Re: PLEASE HELP!!!!!!!!!!!!!!!!!!!! (sutrusu)
do u have a stock bottom end
Old Sep 8, 2002 | 11:18 AM
DLB1994's Avatar
i taking it that u got a stock bottom end its not good news
u got a broken ring landing or pistons damage u got are getting blow by in your crank case making the turbo return line no drain because its to much pressure on the bottom of the engine so this means rebuild time
Old Sep 8, 2002 | 11:30 AM
i just replaced the head gasket...car runs great..if it had a broken ring...the car would run like ****...it spools hard as hell...just smokes...
Old Sep 8, 2002 | 11:35 AM
DLB1994's Avatar
if its only one piston the car will run the same idle the same and every thing
You would not even tell the lose in power
Do a comp test to find out for sure
i have fixed cars like this about 5 times
Old Sep 8, 2002 | 11:42 AM
DLB...
do you have AOL? i need to talk to you on that...not on here..its to complicated
Old Sep 8, 2002 | 12:09 PM
DLB1994...
comp. test results:
#1 120
#2 180
#3 165
#4 170
why would a broken ring make oil come out of my turbo on the exhaust side? and why would that make light smoke come out of the breather tube?
Old Sep 8, 2002 | 12:17 PM
DLB1994's Avatar
DLB1994...
comp. test results:
#1 120
#2 180
#3 165
#4 170
because of blow by the oil the your turbo is trying to drain its getting backed up in your turbo and it got to go some where easy place to come out is your turbine
#1 pistons got ring landing damage the smoke coming out the valve cover is blow by from that piston
Old Sep 8, 2002 | 12:19 PM
Kamin's Avatar
do NOT DRIVE IT LIKE THAT
you could destroy your newly rebuilt turbo.
just in case you needed a little persuation.
Old Sep 8, 2002 | 12:34 PM
i'm not driving it....its sitting has been since yesterday...i drove it like a block to see what was going on...so its just sittin...
Old Sep 8, 2002 | 02:58 PM
JE 81mm pistons from a 97 GSR...will they work in my B18B???
