suggested gauges for SC install
Old Sep 10, 2002 | 08:35 AM
keebler65's Avatar
Default suggested gauges for SC install
if i was to get a JRSC, what are the most important gauges i should have? since they make so many to measure different things.
thankyou
Old Sep 10, 2002 | 08:58 AM
HybridKOOP's Avatar
Default Re: suggested gauges for SC install (keebler65)
Boost pressure, exhaust temp.
Those are the two most important. Third (in my opinion) being oil pressure for ***** and giggles.
Old Sep 10, 2002 | 09:02 AM
jamal-188's Avatar
Default Re: suggested gauges for SC install (HybridKOOP)
I agree, def boost and egt, then go with oil pressure, and you should have a fuel pressure gauges somewhere, I'd just go with a cheap B&M
Old Sep 10, 2002 | 09:09 AM
keebler65's Avatar
Default Re: suggested gauges for SC install (jamal-188)
so egt i assume is exhaust gas temp. why is the temp important? is boost necessary if its a SC? since supposedly the boost is 6psi. i'm just asking because as you can tell i'm new in this area. also what is B&M? thanks for the replies already!
Old Sep 10, 2002 | 09:19 AM
HybridKOOP's Avatar
EGT is exhaust temp, yes... place in the correct location, this gauge will give you a good idea if you're running the engine in a rich or lean condition.
As far as the boost gauge goes... no matter what type of forced induction system you're running -- you'll want to know what boost you're making, and also what vacuum you're making (to ensure a healthy motor at all times).
B&M is a company that makes "cheap" fuel pressure gauges for about 40 bucks new. Another wise investment...
EDIT: Grammar.
[Modified by HybridKOOP, 9:34 PM 9/10/2002]
Old Sep 10, 2002 | 10:20 AM
keebler65's Avatar
ok thanks. the info really helps
Old Sep 24, 2002 | 08:37 AM
RockDawg_GSR's Avatar
Know where any sites that help with the install of gauges( boost, water temp, voltage, air-fuel.) I need some help with wires and shiet. A site with pictures would be nice but anyhitng will do. Thanx A lot.
totsie7944
Jun 25, 2007 05:22 PM
Patron
Dec 20, 2003 01:57 PM
Snafu-Si
Jul 7, 2002 11:48 AM
slewis
Nov 4, 2001 02:32 PM
DIRep972
Jun 15, 2001 11:31 PM
