High Mileage Engine: Smaller Turbo: Worth It?
Hey guys,
I just finished up reading a bunch of the articles over at team-integra.net and linked sites. I get the feeling that a lot of people are ruhning on a t3/4 hybrid turbo. However, since my car has 138,000 miles on it and I'm not planning to run massive amounts of boost, I was wondering if putting a t2/3 turbo, like the author of integra.vtec.net is using, would be worth it? Are there benefits to smaller turbo's? (Don't they spool up faster or something? Less turbo lag?) Can I get to 200 hp with a t2/3 turbo, or is that even a reasonable target for a turbocharged Integra? Will running a smaller turbo increase reliability, or decrease the chance that I will kill my 138,000 miles Integra LS engine?
Thanks,
Ben
[Modified by mr_mbuna, 7:38 PM 9/8/2002]
Thanks,
Ben
Re: High Mileage Engine: Smaller Turbo: Worth It? (mr_mbuna)
dude, first off, team integra is not a reliable source for technical information.
second, the size of hte turbo has nothing to do with your engine lasting longer.
third, waht the hell is a t2/t3 turbo?
fourth, the size of the turbo does not matter. it's how much you boost. to get up to 200 whp or at least somewhere around there you need to boost around .45 bar.
fifth, click search at the top before you post.
Re: High Mileage Engine: Smaller Turbo: Worth It? (sutrusu)
Hope this clears it up,
Ben
as for team integra, they are more concerned with visual mods, IE painting tail lights, changing antennas, etc. a lot of people on there don't know what they're talking about.
about running boost on your engine. you shuld get a compression /leakdown test and make sure everything is running good. if it's not, you're going to either A. rebuild it and turbo the hell out of it or B. forget the whole idea of turbo
maybe there is a t2/t3 turbo, but i have never heard of anyone using it.
Okay, thanks for the less-aggressively-toned post, sutrusu. So I should get a compression test done, and if the results come out OK, then I can safely boost 7 psi?
If I only want to boost 7 psi to get to 200 hp, then wouldn't a smaller turbo than a t3/t4 be a better choice since it would spool up faster? What is the best size/model turbo choice to boost a '95 Integra LS engine to 200 whp?
Thanks for the bar-to-pounds-conversion, skhonda.
Ben
Ben
Dorikamu
11-04-2002 12:21 AM
