IAT question
Old Sep 9, 2002 | 10:32 AM
b00stedsi's Avatar
Default IAT question
hey guys, i have a drag3 kit in my 00 Si. what do i do with the IAT. i know it should go in the charge pipe but there is no bung. Any info will greatly be appreciated.
[Modified by turkish, 7:33 PM 9/9/2002]
Old Sep 9, 2002 | 11:23 AM
CzanSOHC's Avatar
Default Re: IAT question (turkish)
don't put it in the charge piping..relocte it just after the filter.
Old Sep 9, 2002 | 01:03 PM
BlwnBlue's Avatar
Default Re: IAT question (CzanSOHC)
I drilled my charge pipe and bought a rubber fitting from autozone to put in the hole..works perfectly in the stock location(as if the stock intake was still on)
Old Sep 9, 2002 | 01:05 PM
abraunb16's Avatar
New User
Default Re: IAT question (BlwnBlue)
Me, too!
Old Sep 9, 2002 | 01:09 PM
sgT's Avatar
sgT
NO. you should put an older style IAT in your intake manifold or else the ecu will get incorrect readings and the car will run poorly. keeping it in the charge piping
is okay, but still not as good
Old Sep 9, 2002 | 02:42 PM
b00stedsi's Avatar
the air will be colder in the charge pipe since it's after the intercooler. as of right now my car is running like **** and its because i have it after the filter, and the ecu is not receiving the correct info. Thanks guys, also have you ever had it blow out?
accordbeliever
Feb 25, 2013 08:49 PM
shutta
Sep 23, 2005 11:39 AM
Fatty_1775
Jul 27, 2003 10:30 PM
Boost2NA
Aug 9, 2002 10:37 AM
