fuel pressure in excess of 99 psi!?!?!?!
Old 09-08-2002, 12:07 PM
B18EG6's Avatar
Default fuel pressure in excess of 99 psi!?!?!?!
hmm ok. Well. drag kit on a gsr...airtex inline fuel pump, vortech FMU 12:1 plate. Around idle I have about 45 psi Fuel pressure reading on my **** digy gauge I stole from my friend. At full boost it pegs out at 99 psi. IS this normal? I feel a sligggggght hesitation in acceleration when it reaches this insane number. Is it supposed to go this high?
thanks a lot
b18eg6
Old 09-08-2002, 12:22 PM
civictypenos's Avatar
Default Re: fuel pressure in excess of 99 psi!?!?!?! (B18EG6)
its never good to run that high of fuel pressure on a honda,it slows your injectors,overworks them and eventually kills them,but with a 12:1 fmu that is normal,your increasing your psi by 12 for every pound of boost over your base.so if you run 8 pounds of boost with a 12:1 fmu,you have 96 psi + your 45 at idle,thats crazy.its alwyas better to use bigger injectors and smaller fmu,are you running lean or rich??
Old 09-08-2002, 12:28 PM
B18EG6's Avatar
Default Re: fuel pressure in excess of 99 psi!?!?!?! (civictypenos)
im rich as hell (haha no pun intended)
what size injectors and what size fmu would u reccomend?
thanks
Old 09-08-2002, 12:35 PM
my own set up is as follows:b16a3 in 95 coupe with obd1 ecu.im using a t3 saab turbo,with intercooler and all the trimmings(intercooler,BOV...etc.)im using 370cc rc's with a aem fuel rail(makes no differnce),vortech fmu with a 4:1 disc,walbro 255 intank pump.im using a vafc to lean it out for good idle.i had leaning out probelms til i ran the bigger injectors,im running about 82 psi at full boost of 10 pounds,then using the vafc to put it closer to exactly where i want it specificaly,all a fmu does is get you in the right neighborhood,they are not exact and not very trust worthy,if i was in your shoes,get injectors and a vafc,and see if you can put a smaller disc in your fmu.then your getting less stress on all your other components and putting more fuel in the motor where it needs to be instead of building useless pressure in the fuel lines.
Old 09-08-2002, 02:24 PM
shadowdawn's Avatar
I recommend knocking your timing to 12deg or less, getting 440cc injectors, afc set at -40% across the board hi and lo throttle, and base fuel pressure at 40psi with vac line disconnected and plugged...
Old 09-08-2002, 02:45 PM
liam821's Avatar
Default Re: fuel pressure in excess of 99 psi!?!?!?! (shadowdawn)
i couldnt have said it better myself
liam
Old 09-08-2002, 03:03 PM
shadowdawn's Avatar
Default Re: fuel pressure in excess of 99 psi!?!?!?! (liam821)
liam
Well its because of you I discovered this great poor mans standalone setup and have studied inside and out and now am running it :D
Old 09-08-2002, 07:16 PM
B18EG6's Avatar
keep the inline pump and FMU?
[Modified by B18EG6, 11:16 PM 9/8/2002]
Old 09-08-2002, 07:20 PM
B18EG6's Avatar
oops i forgot to click the box that emailed me....sorry. but keep the inline and the FMU?
musclefella
05-01-2004 01:31 AM
b18c1wes
02-12-2004 09:12 PM
Familycarfromhell
02-09-2003 07:40 PM
BorderM3
11-05-2002 10:54 AM
civbeater90
08-28-2002 02:15 PM
Quick Reply: fuel pressure in excess of 99 psi!?!?!?!
