Will this dp fit both these turbos?
i was wondering this, if i have a drag/maxrev/revhard mani. and i have my volvo t3 on it and a downpipe that works. will that same downpipe fit something like a t3/to4e? im thinking it wont because its a t4, but am i wrong?
also, if im running that volvo turbo on one of those manifolds what is a good way to seal the place where the external wg goes, allowing the external wg to be used when i upgrade to the bigger turbo.
oh, and one more Q , if i have all my piping setup with the volvo turbo and then get the bigger turbo, what probs will i have with the ic piping?
Re: Will this dp fit both these turbos? (blufke)
They share the same downpipe. allthough its a t4 compressor housing the t3 downpipe should work.
i think, anyine else?
Rob
Rob
Re: Will this dp fit both these turbos? (rjardy)
they probably (actually, they do) have different bolt patterns. my t3 has a wierd *** exhaust bolt pattern, and now i have to get a flange made and cut the downpipe i just bought
Re: Will this dp fit both these turbos? (sutrusu)
some t3 so ahve different bolt patters, the older t3's usually have 4 bolts and the newer one have 5 bolts.
Rob
Rob
anyone know? its off an 87-89 volvo 740 turbo with intercooler. will the two turbos bolt up to say a maxrev bseries manifold and be able to use the same dp? and what is a good way to block off the wastegate port until one is used with the next turbo?
biada1
11-28-2006 12:53 PM
