D16Y8 and turbo in EF ?
Old Sep 6, 2002 | 10:02 PM
AdamEF's Avatar
Default D16Y8 and turbo in EF ?
I'm dropping in a new engine D16Y8 with plans of going turbo/sc eventually,
i've used the SEARCH and came up with not much on the D16Y8 +turbo
What kind of PSI should I run on stock internals? The engine has about 30000kms
on it. My estimate would to leave it a 6 psi but what would I have to do to maybe go a little higher?
Old Sep 6, 2002 | 10:20 PM
Smashback's Avatar
Default Re: D16Y8 and turbo in EF ? (AdamEF)
I'm running 9 PSI right now on a stock D16Y7 block w/D16Y8 head. Custom T3/4 setup, runs great. I was running 7 PSI for about 8 months and then cranked it up to 9. I'll probably run 10 or 11 once I get a Hondata or something tunable.
Old Sep 7, 2002 | 05:10 AM
turbopanda's Avatar
wanna boost 10-18psi? https://honda-tech.com/zerothread?id=267641
Old Sep 7, 2002 | 10:01 AM
Midwestrider's Avatar
Default Re: D16Y8 and turbo in EF ? (mplex2000)
mplex2000 w/ your t3/t4 when do you reach full boost by? when do your start to spool by? also what a/r and trim sizes are your turbo?
i was looking at possible a t3 super 60 for my d16y8. shooting for 8-10 psi on stock w/ hondata etc... till motor built and then run 12-15psi or try using a t3/t4 instead of super 60.
when talking w/ Turbonetics they suggusted the t3 super 60 w/ .48 a/r w/ std wheel on turbine
any input?
Old Sep 8, 2002 | 09:37 PM
AdamEF's Avatar
How do i go about building it up? I want to safely run 8-10psi
what can i do with the engine still in the car?
Old Sep 8, 2002 | 09:56 PM
CzanSOHC's Avatar
you want to build the bottom end up....not much you can do while your engine is still in the car(internal wise) you can run 8psi safe on stock internals...granted you have colder plugs and retard your timing...
Old Sep 8, 2002 | 10:04 PM
AdamEF's Avatar
Default Re: D16Y8 and turbo in EF ? (CzanSOHC)
ok so best bet is to get it tuned properly.... and invest in a good fuel system......
hondata too..
Old Sep 8, 2002 | 10:07 PM
CzanSOHC's Avatar
hondata too..
Thats 90% of it my friend.
Goon360
Dec 8, 2009 10:52 PM
jesusjdm69
13
Jan 25, 2009 09:36 AM
unknownracing
Jul 26, 2007 11:05 AM
Turb00HC
May 20, 2004 06:07 PM
