Fuel system guys....
Old Sep 7, 2002 | 07:10 AM
Blown90hatcH's Avatar
Default Fuel system guys....
Those of you who have done a full fuel system...(I am putting this on soon.....Aeromotive pump, braided lines, regulator, etc.) What did you do with the stock fuel lines? Take them offf completely? Leave them there?
Thanks, Jason
Old Sep 7, 2002 | 07:19 AM
ekb18c's Avatar
Default Re: Fuel system guys.... (Blown90hatcH)
I took them off completely.
Old Sep 7, 2002 | 07:37 AM
civbeater90's Avatar
Default Re: Fuel system guys.... (ekb18c)
dude check it ou.if you don;t to replace the stock lines,heres a suggestion.i just found russell fittings that go from a hard line to an fitting.it doesn't need a flare comes with special compression fitting.so just cut your ends off and install these.but if your gonna make power that exceeds ths stock line limits well forget what i said.hope it helps.i can get you part numbers if you need too.just im me
Old Sep 7, 2002 | 07:52 AM
93LSivic's Avatar
Me too. Twisted them up and left them on the curb for Monday trash pickup.
Old Sep 7, 2002 | 08:54 AM
Default Re: Fuel system guys.... (civbeater90)
What are the stock lines rated for?
Old Sep 7, 2002 | 10:30 AM
im not positive in this but if i rember correvtly they can handle up to 400.but to be sure i would make a seperate post and ask that question.
Old Sep 7, 2002 | 11:50 AM
Farnsrocket's Avatar
Tore em off like I was starting a lawnmower.
Old Sep 7, 2002 | 04:27 PM
Bnjmn's Avatar
The stock lines are pretty small (don't remember, but I measured and they were too small for a real turbo install), the compression nuts he's talking about are for using hard lines. MUCH cheaper than the braided, though they don't look as cool.
You can get 25' of Stainless -8AN for $30 or so at Summit and then just use the compression nuts to fit to the -AN fittings on the fuel pump/filter/regulator.
Ben
Old Sep 7, 2002 | 05:05 PM
Default Re: Fuel system guys.... (Bnjmn)
25' of -8 SS line for $30?!?!?!? I'd like to see that!
Old Sep 7, 2002 | 05:40 PM
D-Man's Avatar
I dont know if one of those compression fitting would be safe to install,theyre made to fit standard size lines like 3/8s,1/2, etc not the metric stuff that our cars use.
Old Sep 7, 2002 | 06:02 PM
PrecisionH23a's Avatar
Default Re: Fuel system guys.... (Farnsrocket)
i removed all of my lines also, but i decided to save them in case i ever need them again, im sure honda charges an arm and a leg for them. i ordered all my fuel lines and fittings from summitracing.com, they had my stuff to me 2-3 days after i ordered them. youre looking at roughly $500-600+ for feed lines, return lines, fittings, adj fpr, fuel filter, grommets, etc. when i ran my new lines i used hose clamps hold the new ones in place underneath my car.
Old Sep 7, 2002 | 06:06 PM
Default Re: Fuel system guys.... (GudeH23a)
summit racing----------->
Old Sep 7, 2002 | 06:24 PM
93LSivic's Avatar
amstreetrod.com
This is the best and only place you should go for Earls products. Great service, prices, and its their specialty.
Old Sep 7, 2002 | 06:42 PM
Default Re: Fuel system guys.... (93LSivic)
Amstreetrod.com -8 90 degree tube hose end #809108 $24.74
-8 swivel seal straight #800108 $9.57
Summitracing -8 90 degree tube hose end #809108 $20.95
-8 swivel seal straight #800108 $7.75
you choose who you want to buy from
Old Sep 7, 2002 | 09:15 PM
Bnjmn's Avatar
Summit part #'s - SUM-220238 for -6AN SS, 20'
SUM-G2512 for aluminum -8AN, 25'
I agree that the compression nuts aren't for the stock lines, only for -AN sized lines.
Ben
Old Sep 8, 2002 | 11:06 AM
93LSivic's Avatar
They must have raised there prices. When I did my full fuel system I compared overall price on the needed parts. I did save a considerable amount over what Summit priced everything out to be. If you look, some of summits prices are higher on different fittings. For those particular fittings obviously summit is cheaper.
Old Sep 8, 2002 | 12:53 PM
That's cool. I didnt look at everything.........it seems Summit's line was cheaper too.
Thanks!!
jdm_h22
Dec 4, 2012 03:16 PM
marcj
Sep 28, 2010 10:40 AM
92DAturboteg
Dec 19, 2006 01:28 PM
gendai_8
Jul 16, 2003 09:43 PM
