Idle Surge
Old Sep 9, 2002 | 08:20 AM
darrenwall's Avatar
Default Idle Surge
I have finally got all of the issues with my supercharger install
solved except one: I have a a "surge" at idle. While idleing, the
rpm's sruge from idle (about 900rpm) to about 1400 rpm, then back.
I thought the problem might be the air temp. switch and the new
relay, so I checked the circuit and the switch, both seemed fine. I
plan on checking the idle air control solenoid tonight, but it seems
wierd it would pick now to go out.
Any ideas?
Best Regards,
Darren D. Wall
darrenwall@netzero.net
1995 Civic DX HB
Go: Gude, AEM, DC Sports, Weapon-R, 5-Zigen, JR Supercharger!
Turn: AGX, Tenzo-R, Pirelli
Look: PPG, APC, Wings West
Old Sep 9, 2002 | 03:53 PM
blueturbo99's Avatar
Default Re: Idle Surge (darrenwall)
I had same problem. Come to find out The car was to lean at idle.
Turned the fuel up at idle(v-afc) and I don't have the problem no more.
Old Sep 9, 2002 | 03:55 PM
98civicEX's Avatar
curious..did u ever disconnect the TB or intake mani?
Old Sep 9, 2002 | 04:30 PM
.nate's Avatar
Default Re: Idle Surge (98civicEX)
You may be low on coolant...
Old Sep 9, 2002 | 04:53 PM
darrenwall's Avatar
Well, first I checked for vaccum leaks. Sprayed carb cleaner on every connection and all over the intake manifold circuit, absolutely no change. I then checked the IAC circuit: When I disconnect the IAC connector, the idle immediately evens out. It doesn't decrease, just even outs? I checked the connector, battery voltage at the black/yellow wire. I then ohmed the IAC valve itself; zero ohms when warm. The book says it should be 5-8 ohms. Sound like a bad IAC valve?
Best Regards,
Darren D. Wall
1995 Civic DX HB
dohc_profile
Feb 17, 2009 09:19 AM
EGIan
10
Feb 11, 2009 07:52 PM
fresheg760
Jun 7, 2008 06:33 AM
jdmgeezer
Dec 9, 2007 11:23 PM
mobebk
Nov 2, 2006 03:24 PM
