Apex kit, what all is needed to complete the install...
Old Sep 9, 2002 | 08:58 AM
mantic6t9's Avatar
Default Apex kit, what all is needed to complete the install...
I know the apex kit has been beat to death but i still havn't been able to find the answer to my question. I'm pretty sure you need a WG and BOV. What eles. I don't plan on running more then 10psi and will proble keep it at 7psi for a while. What type of fuel management would i need? I notice alot of people using Just and FMU and Fuel pump. I want to know my options without going to a Stand Alone at this point, maybe down the line. If you guys could give me priced on the stuff i'll need that would help too. Thanks.
Travis
[Modified by mantic6t9, 11:59 AM 9/9/2002]
Old Sep 9, 2002 | 09:02 AM
senpai's Avatar
Default Re: Apex kit, what all is needed to complete the install... (mantic6t9)
You don't NEED a BOV, but then what's the point of the turbo kit? It has a wastegate, it's internal.
Fuel? I use the AFC trick.
Old Sep 9, 2002 | 09:25 AM
mantic6t9's Avatar
Default Re: Apex kit, what all is needed to complete the install... (maztur)
Out of these two options what is better?
Vortech FMU, Fuel pump, check valves, ect..
or
440 injectors and s-afc/v-afc? do you need a fuel pump with this combo?
Travis
Old Sep 9, 2002 | 09:29 AM
CzanSOHC's Avatar
or
Travis
I would go w/ the AFC/ innjector route, and get a fuel pump w/ either though.
here is moe info: http://www.thedropshop.tv/vafc.htm
Old Sep 9, 2002 | 03:55 PM
Midwestrider's Avatar
If you are referring to the apexi kit which is for the d16's, the wastegate is internal on the turbo. As far as the bov it is optional, i sugguest in getting one.
If you are opt'ing not to get a standalone most seem to like the vafc/afc hack.
Below is some post on that hack setup, you can do a search and find more info also.
info related to the afc hack:
https://honda-tech.com/zerothread?id=137901
https://honda-tech.com/zerothread?id=270290
stussy8280
Sep 5, 2005 06:31 PM
OptPrime
Jul 17, 2005 09:40 AM
94hybridcoupe
Apr 6, 2005 06:53 AM
mey_xanng
Dec 9, 2002 02:13 AM
shadowdawn
Apr 4, 2002 10:19 AM
