Hesitation/Miss seems to be getting worse, need help
Since I got the ZC I have had a slight miss/hesitation. I adjusted a few things and tightened a few motor mounts and the hesitation went away. The slight miss was still there though.
I installed the Greddy kit along w/ a MSD 6A, modded cap, Accel coil, new NGK BKR6E-11's, adjusted timing (-2degrees from stock), replaced fuel filter, hooked up FMU, and so on.
It seems to be getting worse now. It's just a total lack of power when a semi throttle. If I go WOT, it will jump a little and take off. I am getting all kinds of small backfires out the muffler when off the throttle or just barely touching it.
Does anyone have any idea what this could be? My a/f sways in the stoich/little bit in to the lean when cruising, and goes to rich @ WOT when the FMU kicks in.. It's getting aggrivating...
I checked the vacuum lines, but can't seem to find anything wrong. Does anyone have this diagram again, and I'll double check again to make sure.
jB
jB
BoostedB16EF8
01-26-2004 03:52 PM
redzcstandardhatch
12-21-2002 11:19 AM
