is an intake for the turbo necessary?
Old Sep 9, 2002 | 07:48 AM
TurbothisLS's Avatar
Default is an intake for the turbo necessary?
i've heard some people just clamp a wire fencing to the intake side of the turbo...
how necessary is the intake pipe and filter ?
Old Sep 9, 2002 | 08:19 AM
Slick GS-R's Avatar
Default Re: is an intake for the turbo necessary? (TurbothisLS)
bump
Old Sep 9, 2002 | 09:06 AM
ekb18c's Avatar
Is it necessary? Hmm No, not really. Did I put a filter on my turbo? YES!!
The wire screen will only stop large pebbles from going into turbo. What about dirt and smaller pebbles? Do you really want a lot of dirt going into your motor? Do you want to risk the turbo getting messed up because of a little pebble? Better safe then sorry!
HTH
Old Sep 9, 2002 | 09:16 AM
autoEXturbo's Avatar
i agree, i always used the filter on the street. Now when i went to the track i would switch to the wire, i don't know if it really helps much, but that's just me trying to get everything i could out of my car.
Old Sep 9, 2002 | 09:28 AM
PrecisionH23a's Avatar
the turbo application for the H series dont come with filters, well at least they dont with the drag gen 2 or 3 kits. i ran the clamp with fine screen mesh over it for a while and it was fine. its a little safer to do this on the H series since the turbo sits up so high, basically right against the hood. i ended up making my own filter piping and adding a filter though just for that extra sense of security.
Old Sep 9, 2002 | 03:47 PM
DLB1994's Avatar
Default Re: is an intake for the turbo necessary? (GudeH23a)
i dont have nothing on my turbo but i got the H series engine
the B series where the turbo sits down near the block and of u run open dump tube on your wastegate i would run a filter
Or your turbine wheel will start looking bad real fast
Old Sep 9, 2002 | 04:13 PM
HybridKOOP's Avatar
Default Re: is an intake for the turbo necessary? (DLB1994)
I have seen cars suffer on the dyno from having no filter element attached to the turbo because of the location of the compressor on a B-series engine, which happens to be sucking air right in from a hot radiator. HP gains were shown when the turbo pulled air from the corner of the bay just behind the headlight, even with a "restrictive" filter on the extended pipe.
Old Sep 9, 2002 | 04:17 PM
B18EG6's Avatar
how much boost are you running?
go here...
https://honda-tech.com/zerothread?id=269244
scroll down to gudeh23a's post and thats why i asked about how much boost yer running
[Modified by B18EG6, 8:25 PM 9/9/2002]
Old Sep 9, 2002 | 11:19 PM
Default Re: is an intake for the turbo necessary? (B18EG6)
does anyone have one for sale??
Old Sep 9, 2002 | 11:23 PM
dustin's Avatar
Use a filter.
I've seen a compressor wheel destroyed by this fine "filtering" method. Looks like someone put gravel in the compressor inlet.
Old Sep 9, 2002 | 11:40 PM
blufke's Avatar
Default Re: is an intake for the turbo necessary? (dustin)
i plan on using the filter from my cai. just clamping that on should work fine right?
touny1979
Apr 25, 2007 06:33 AM
Schister66
Jun 10, 2006 02:36 PM
nitrousrush
Aug 2, 2004 11:15 AM
turboex
Jul 10, 2002 06:45 AM
