Turbo for my LS powered hatchhback
Old Sep 8, 2002 | 08:43 PM
Jeff 360's Avatar
Default Turbo for my LS powered hatchhback
So I'm gonna be in the position to purchase a brand new turbo kit in the end of October. I'm new to the idea and concept of turbo...but I've adopted the idea from VW that "Turbo makes it better" who here that knows alot about turbos can recommend me a good turbo setup for an LS motor in a hatch, I don't need mad power but I want a bigggggggggggg intercooler and somethin' that can boost about 12 to 15 lbs. down the road. Even a little more maybe. Please anybody knowlegable in this area please post.
Old Sep 8, 2002 | 08:44 PM
SIK IN DA HED's Avatar
New User
Default Re: Turbo for my LS powered hatchhback (Jeff 360)
DRAG3 and Hondata
Old Sep 9, 2002 | 01:59 AM
Jeff 360's Avatar
Default Re: Turbo for my LS powered hatchhback (dlplayboy)
that is not enough info. If I were to do a setup like that what would the Drag 3 cost, I know how much hondata would be.
Old Sep 9, 2002 | 04:02 AM
Foozball26's Avatar
If you need that much detailed info then search, It is your friend.
Theres soo much info on this topic its not even funny so if you say you cant find any then step away from the computer and car and buy a moped
Old Sep 9, 2002 | 07:59 PM
Jeff 360's Avatar
Default Re: Turbo for my LS powered hatchhback (foozball-26)
Eat a #$#@ fool, I'm just doin' research for myself, bump a search. I just assume doin' this post apposed to searching, it's more time efficient for me!
Old Sep 9, 2002 | 08:10 PM
hydroflip's Avatar
Old Sep 9, 2002 | 08:43 PM
DIRep972's Avatar
Smarter than you
get a good turbokit like drag 3. make sure u get a deltagate wastegate, they are tried and true. THe FMU from the kit and stock injectors work great up to 15psi. good luck. search sucks! I give u all the answers no problem man.
Old Sep 9, 2002 | 08:48 PM
Ri5e's Avatar
Default Re: Turbo for my LS powered hatchhback (DIRep972)
If you want good street power, listen to what DIRep said. S-AFC + FMU Combo are a must for big power.
Old Sep 9, 2002 | 08:56 PM
DIRep972's Avatar
Smarter than you
Default Re: Turbo for my LS powered hatchhback (CRV Monster)
yeh the stock fuel system is only good for 7psi. u need an FMU at anything above that.
Old Sep 9, 2002 | 09:38 PM
DA666's Avatar
what he said
Old Sep 9, 2002 | 09:45 PM
bryan305's Avatar
Default Re: Turbo for my LS powered hatchhback (DA666)
You'll want to go with a 1.75 inch or smaller down pipe to create some backpressure to help spool quicker. Also, to help with the fuel, bypass the filter as that creates a restriction and can reduce fuel pressure. BOV's are bad because they actually let out your boost. Don't put one on unless it's just for the sound.
Old Sep 9, 2002 | 09:58 PM
Civicdrgrcr's Avatar
From: WTF DC Racer No Way Turbo Washington., DC, USA
Default Re: Turbo for my LS powered hatchhback (bryan305)
First of all. It depends how big you want to go, how fast you want to go. Is your car going to be like a all out stripped out street/strip car, etc...
Go custom. Piece your own kit togther. Send me a Pm ill hook you up on turbo parts. OR email or pm b18bturbo.
Check my bio for my info on my car. I used to have a ls turbo hatchback best time was 13.1 on street tires.
Old Sep 9, 2002 | 10:03 PM
HybridKOOP's Avatar
Exactly what he said... although I wouldnt use a wastegate at all... just have the opening on the manifold for the wastegate welded shut... max out a T3/T4 and you'll be happy with the results.
As far as fuel goes, find a set of Civic CX injectors and use a inline pump with the polarity backwards.
Old Sep 9, 2002 | 10:05 PM
speshuled619's Avatar
im sorry bro but if you want a turbo to spool quicker you need a bigger dp like 2.5 or even 3inch. back press. may be good for n/a in some instances but for boosted cars no. and as far as BOV's being bad, i dont see that possible. its job is to have the extra press of air to exit the charge pipes so it doesnt hit your throttle plate and cause lag and when it hits the throttle plate it goes back in the direction of the turbo and can reduce the life of your turbo because the turbo is pushing air one way and you have the extra air pushing the other way which puts stress on the turbo wheel and bearnings. BOV's are also adjustable so that you dont have the spring set too loose and have it open early and loose boost.
and i think a good enough setup for the street would be an adjustable fmu with a inline pump a s-afc and maybe injectors. but the most important thing is to TUNE TUNE TUNE. put it on a dyno and tune it using a wideband 02.
Old Sep 9, 2002 | 10:57 PM
highmilehatch's Avatar
Default Re: Turbo for my LS powered hatchhback (speshuled619)
Yeah, tune for an a/f ratio of somewhere around 15:1 under max boost. Oh yeah, dont forget to run hotter plugs and advance the static timing.
Old Sep 9, 2002 | 11:00 PM
Vsm Hatch's Avatar
[QUOTE]im sorry bro but if you want a turbo to spool quicker you need a bigger dp like 2.5 or even 3inch. back press. may be good for n/a in some instances but for boosted cars no. and as far as BOV's being bad, i dont see that possible. its job is to have the extra press of air to exit the charge pipes so it doesnt hit your throttle plate and cause lag and when it hits the throttle plate it goes back in the direction of the turbo and can reduce the life of your turbo because the turbo is pushing air one way and you have the extra air pushing the other way which puts stress on the turbo wheel and bearnings. BOV's are also adjustable so that you dont have the spring set too loose and have it open early and loose boost.
QUOTE]
HaaHAHA OMG!!! LOL!!!
Seriously... that made my day!! (& its been reallly shitty)
Deng thats just evil.. the guy doesn't get the drift
Old Sep 9, 2002 | 11:27 PM
synergy004's Avatar
Default Re: Turbo for my LS powered hatchhback (LiL_Kid)
lol
Old Sep 9, 2002 | 11:33 PM
st00pid's Avatar
Default Re: Turbo for my LS powered hatchhback (turboeg)
WRONG!!! not 15:1!! 14.7:1!! you trying to blow up the guy's car???
Old Sep 9, 2002 | 11:34 PM
blufke's Avatar
Default Re: Turbo for my LS powered hatchhback (synergy004)
funny. very funny.
Old Sep 9, 2002 | 11:53 PM
Adi Radoncic's Avatar
On Fire!
Default Re: Turbo for my LS powered hatchhback (blufke)
Actually dude just get a JRSC with the 8psi kit, JE piston and Eagle Rod..
Ahhhhh where is Dustin when you need him??
Adi
Old Sep 10, 2002 | 01:14 AM
rjardy's Avatar
Default Re: Turbo for my LS powered hatchhback (newgsr)
Torocharger!!!!
what an ******* this kid is! I rarely curse on this board but this punk blew up at the first guy who told him to do a search. That kinda pissed me off/ That is the same thing that i would have told him. Ignorant people
Rob
Old Sep 10, 2002 | 04:19 AM
lsvtec101's Avatar
i sell a basic turbo kit for 1800 with spearco intercooler... hit me up.
Old Sep 10, 2002 | 12:53 PM
Jeff 360's Avatar
Default Re: Turbo for my LS powered hatchhback (rjardy)
You too can lick me...I'm not a troll nor do I think internet fights are useful but tellin' someone to search is just gay. the info I've gotten from this post has been awsome and is puttin' me in the right direction.
Old Sep 10, 2002 | 01:13 PM
txhatch's Avatar
Good luck im doing the same thing. Waiting for hondata for more boost.
Old Sep 10, 2002 | 01:21 PM
battyx's Avatar
Yeah, DiRep is hookin' you up w/ the info. Instead of listening to that fool Lil_Kid, stick with a 1.75" downpipe, but keep the 1.75" diameter piping all the way through to the exhaust. Widening the exhaust diameter will just create more air turbulance, slowing the amount of air that can efficiently leave your car.
Good luck.
