Post pictures of GM (General Motors) 3 Bar Map Sensor installs
Re: Post pictures of GM (General Motors) 3 Bar Map Sensor installs (integra-modder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra-modder »</TD></TR><TR><TD CLASS="quote">Just curious to get some pics of how you did your installs</TD></TR></TABLE>
Mine is zip tied against my firewall with a vacuum line running off the vacuum log above it, sorry no pics
Re: Post pictures of GM (mskibbz-T)
Mine is secured to my firewall using double-sided foam tape. Hasn't moved an inch in over 8 months. Just make sure you clean the dirt/grease from the metal and you're set.
Re: Post pictures of GM (TAG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TAG »</TD></TR><TR><TD CLASS="quote">Mine is secured to my firewall using double-sided foam tape. Hasn't moved an inch in over 8 months. Just make sure you clean the dirt/grease from the metal and you're set.</TD></TR></TABLE>
Thats a good idea....
Here we go from start to finish:
I cut the bracket that comes with greddy turbo timers and boost controllers and attached a small piece of thin metal to it.
Then I attached the MAP to it:
I then used an existing bracket to mount the small metal piece
Once attached the map looks like this
Wiring
Wiring
jeffchaisi
03-27-2005 10:39 PM
