Check Engine code is non-terminating long flashes??
Old Oct 17, 2003 | 02:27 PM
92TEGsrSC's Avatar
Default Check Engine code is non-terminating long flashes??
wth is going on. I'm pretty sure I'm checking the code correctly because I have done it before... but anyway, does anyone know what this code is/means? I have a helms book at my appt at school-- but unfortunately I'm sick right now... high fever and throat infection isn't cool..
Thanks in Advance.
Zack
Old Oct 17, 2003 | 02:34 PM
hoggy's Avatar
Default Re: Check Engine code is non-terminating long flashes?? (92TEGsrSC)
Long flashes repeated would be code 10 I believe. That would be your IAT if I'm not mistaken.
Old Oct 17, 2003 | 02:35 PM
TeStUdO's Avatar
long flashes are 10's
how many long flashes do you get? does it just keep going? Code 10 is IAT try cleaning it.
Old Oct 17, 2003 | 04:35 PM
EKweezy's Avatar
non-terminatina long flashes, it flashes when motor is on and when your driving it also right, check your compressions if it could be it or not
i boosted my stock 99si B16, i bent a intake valve, didn't know i bent a valve, motor was still pulling strong with a Greddy 18g kit, untill my motor starts to idle low and die, checked my compression, it was like 70 at cyc 4. changed the valve, now no more codes,
pclouthier
Honda Civic (2001 - 2005)
Jul 6, 2014 03:01 AM
92TEGsrSC
Oct 17, 2003 02:42 PM
y2ks2k
Jul 26, 2003 05:56 PM
lsvtec101
May 13, 2003 08:09 AM
racerboyb18c
Dec 12, 2002 11:15 PM
