installing apexi turbo timer
Old Oct 18, 2003 | 03:54 PM
Ek00fbp's Avatar
Default installing apexi turbo timer
I have a 00 si with the stock ecu right now. But, I am going to be putting in hondata with a p28 ecu.
Should I wait to install the turbo timer untill after I have the p28 ecu in?
Also, on an obd2 car there are two 02 bungs. When i switch to the obd1 ecu which 02 sensor stays working?
What do i do with the sensor that is not needed? or is it needed?
thanks for the help.
Old Oct 18, 2003 | 09:12 PM
Ek00fbp's Avatar
Default Re: installing apexi turbo timer (Ek00fbp)
bump
Old Oct 19, 2003 | 12:22 AM
lsdhatch's Avatar
the primary o2 sensor is the one that works on obd1 ecu's, if i'm not mistaken
Old Oct 19, 2003 | 01:05 AM
Ek00fbp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ek00fbp &raquo;</TD></TR><TR><TD CLASS="quote">I have a 00 si with the stock ecu right now. But, I am going to be putting in hondata with a p28 ecu.
Old Oct 19, 2003 | 02:16 AM
Trac226's Avatar
You will be splicing into the primary o2 sensor wire either way, you're good to go on installing it. Also, don't get lazy like I did and leave the parking brake wire off, it's an added layer of security.
I used the wiring diagram on greddy's website for their timer, it was easier to understand.
Equilibrium
Jul 21, 2005 08:41 PM
importboi22
Nov 18, 2004 07:53 AM
JBk24crx
Oct 22, 2003 07:57 PM
Projectg2i
Dec 16, 2002 02:30 AM
