B18C1 Dyno (Not what i expected) 278.7 WHP
okay, i got a few problems.
this is a dyno at 13 psi, the setup is..
1994 B18C1 81.5 mm.
JE 9.0:1
Eagle Rods
STR blockguard
Max-Rev manifold and downpipe(2 1/2")
Max-Rev IC w/ Revhard IC piping
Garrett T3/To4e .57 trim, .63 ar
Tial 35 mm HP wastegate
Greddy Type S BOV
3Â’ Thermal exhaust
Skunk2 camgears
Skunk2 manifold
Hondata 2B
RC 550 cc.
Walbro 255 lph
is it me or are the numbers wayy too low??
also, im having rough idle after boosting it a good bit.
tuner told me that i should get a fuel pressure regulator and a fuel rail and
that it will make my idle smoother. is there truth to that? anyone else have this problem.
well, heres the dyno sheet. any input would help.
personally im kinda disappointed in the power.
1994 B18C1 81.5 mm.
JE 9.0:1
Eagle Rods
STR blockguard
Greddy Type S BOV
3Â’ Thermal exhaust
Skunk2 camgears
Skunk2 manifold
Hondata 2B
RC 550 cc.
Walbro 255 lph
Re: B18C1 Dyno (savannakhet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by savannakhet »</TD></TR><TR><TD CLASS="quote">maybe the compression on those pistons are too low.</TD></TR></TABLE>
i doubt it, ive seen many people with 9.1 makin lot better power than me.
concerning the a/f ratio charts......
i completely forgot about those charts, i was way too pissed. im gonna try to email him and see if he still has the charts and maybe he can send them to me. if he does ill post them up
Re: B18C1 Dyno (94goldjungsr)
2.25" downpipe and stock throttle body are hurting you and if you do a little head porting that would help too. Also if you have cat take it off.
Good torque numbers. Torque is all that really matters anyways
Re: B18C1 Dyno (S03Burner)
I believe the dp he listed was 2.5 And a stock throttle body won't hurt power that much. It might just be due to low compression and a 57trim turbo. Not bad #'s. They aren't really high, but everything looks smooth.
Re: B18C1 Dyno (TurboTegB18c)
There is definately something wrong...
My friend made 275whp with a stock b16 with a blitz headgasket, fmu, and a dragIII kit at 10psi. This was like 3 years ago too...
You need to keep looking cus they're is something wrong, perhaps you can try another tuner..
Re: B18C1 Dyno (MaxBoost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaxBoost »</TD></TR><TR><TD CLASS="quote">
You need to keep looking cus they're is something wrong, perhaps you can try another tuner..</TD></TR></TABLE>
well, lot of people on this board from GA go to him and have had very good experience. im almost definate its not him
Re: B18C1 Dyno (Not what i expected) 278.7 WHP (-iLLuZioN-B18C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -iLLuZioN-B18C1 »</TD></TR><TR><TD CLASS="quote">
that it will make my idle smoother. is there truth to that? anyone else have this problem. </TD></TR></TABLE>
no.. such problems should be related to tuning, at least not fuel rail.. f.p.r can make tuning easier.. other than that it doesn't seem too low of numbers for your setup.
Ask your tuner what your total timing is at full boost. Or get some dataloges and post them if possible.
ill find out more info tomorow hopefully, i just emailed him asking for the a/f sheets and hondata tune sheets, hopefully he will send them to me.
Re: B18C1 Dyno (Cramerox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cramerox »</TD></TR><TR><TD CLASS="quote">i would look into that maxrev intercooler.....they arent very effecient IC for high boost application.</TD></TR></TABLE>
but do you think that the intercooler could hinder the power that much? too tell you the truth, at 13 psi i was almost definate i would hit 300 whp.
Listen to what ED told you to change... He knows his stuff. I have taken my car to him both times for tuning and I have been pleased both times.
all these people getting lower #'s then what the expected is really freaking me out. if i dont hit 250whp on my turbo setup...im selling the bitch ASAP...so stay tuned in november/december a bunch of turbo **** might be on sale for a 94 integra coupe....
yeah ***** scarring me too... im fixin to run a 60ar 60trim T3/To4e with hondata sidewinder manifold the worx... if i cant break 220-230whp on 8psi in an H23... im gunna be pissed
Re: B18C1 Dyno (92lSilude)
What boost gauge, boost controller? I would check coompression, timing, and then maybe consider if maybe boost gauge/controller is off. Numbers are definetely low
Re: B18C1 Dyno (quikB18B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quikB18B »</TD></TR><TR><TD CLASS="quote">What boost gauge, boost controller? I would check coompression, timing, and then maybe consider if maybe boost gauge/controller is off. Numbers are definetely low </TD></TR></TABLE>
boost guage and controller is greddy. brand new too.
and does anyone know the cause of rough idling after boosting it a few times?
my idle is perfect if i drive it nice and easy, but after pushing it, the idle starts to wobble b/w 200 rpm and 1k
Re: (Turbo E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E »</TD></TR><TR><TD CLASS="quote">more than i got
i love posting my failures</TD></TR></TABLE>
whats ur setup?
whats ur setup?
