Turbo Setup (Opinions)
Old Oct 15, 2003 | 05:21 AM
RedTegLS's Avatar
Default Turbo Setup (Opinions)
Here is the setup I am looking at:
Turbonetics T3/T4 Polished Hybrid Turbocharger
High-Carbon Cast-Steel Turbo Manifold
Closed-Loop Mandrel Bent Downpipe
Intercooler Piping ( 2" and 2.5" 16 gauge mandrel bend mild steel )
Intake Pipe ( 3" 16 gauge bent mild steel )
Turbonetics External Wastegate
Spearco Intercooler ( 99% charge-side efficiency)
K&N Air Filtercharger
Turbonetics Racing Blow Off Valve
2 Additional Lucas Fuel Injectors ( 440 cc)
ERL MF2 Additional Injector Controller ( A fuel injector controller programmed to deliver a 3D fuel map, Delivers up to 2 bar or 30 psi boost )
MSD Boost Timing Master
What else do you recommend? This my first turbo setup but I want to do it right the first time. Any opinions or advice would be great! Thanks!
Old Oct 15, 2003 | 07:35 AM
mamaboy's Avatar
Default Re: Turbo Setup (RedTegLS)
Turbonetics T3/T4 Polished Hybrid Turbocharger >> Precision SC lineup depending on your HP Goals
High-Carbon Cast-Steel Turbo Manifold >> What Company?
Closed-Loop Mandrel Bent Downpipe >> You mean closed looped wastegate dump tube
Turbonetics External Wastegate >> Tial 38mm or 40mm
Turbonetics Racing Blow Off Valve >> Tial, DSM suprisingly is good, Greddy
2 Additional Lucas Fuel Injectors ( 440 cc) >> Or just get larger injectors and a standalone
Old Oct 15, 2003 | 08:08 AM
SpoolnG2's Avatar
Default Re: Turbo Setup (mamaboy)
good luck!
LsVtecCoupe00
Oct 21, 2006 08:26 PM
Novtecdohc
Aug 2, 2005 11:45 PM
Turboteggy
Sep 1, 2004 04:24 AM
xstalkrx
Mar 18, 2003 02:21 PM
M.A.R.C.
Jun 25, 2002 07:31 PM
