02 sensor wiring
Old Oct 19, 2003 | 01:02 AM
Ek00fbp's Avatar
Default 02 sensor wiring
My downpipe has two 02 bungs on them right next to eachother instead of how it should have been done with one where the header is and one where the cat would be. My downpipe eliminates the cat. Anyways i have two bungs where the cat should be so i want to know if i can extend the primary 02 sensor to a bung that is where the cat would be. Thanks
Old Oct 19, 2003 | 02:02 AM
Flamenco-T's Avatar
Default Re: 02 sensor wiring (Ek00fbp)
yes you can extend it out, just cut and solder. Obviously your car is an OBD 2 car wit secondary O2 sensor, you'll throw a CEL for the secondary O2 anyway, unless you converted to OBD1 (which in this cae, you can just unplug the secondary O2 from the harness) or run an O2 simulator to trick the ECU.
stan
Old Oct 19, 2003 | 09:43 AM
Ek00fbp's Avatar
Default Re: 02 sensor wiring (Flamenco-T)
what type of wire to i need to run and what gauge?
Old Oct 19, 2003 | 11:55 PM
Flamenco-T's Avatar
14-16 gauge is fine, any insulated wires will work
stan
Old Oct 20, 2003 | 10:58 AM
tnosloco's Avatar
didint you buy it new did it come with wires I have istalled to the comp.
hatch96y7
13
Jun 17, 2007 04:58 PM
WIb16crxWI
May 18, 2006 12:42 PM
jdmxxdc2
Jan 13, 2005 08:17 PM
964dgsr
Sep 25, 2003 07:53 AM
shivers
Apr 19, 2002 06:05 AM
