JRSC fitment issue
Old Oct 17, 2003 | 11:51 PM
REX VT's Avatar
Default JRSC fitment issue
Will a JRSC 989-600 - for the B18c5 engine fit a B16a1? It probably shall but are the dimensions thesame as the 989-250 kit (B16a2) since it will have to fit inside a CRX engine bay (EE8/EF8). I can get a good deal on a used one
Old Oct 18, 2003 | 04:15 AM
greekspeed's Avatar
Default Re: JRSC fitment issue (REX VT)
the bolt pattern for the intake manifold for the b18c5 and b16 are identicle........ so it shoud bolt on no problem...
u might be short for space though due to the firewall ebing so close to the engine..
Old Oct 18, 2003 | 04:32 AM
keebler65's Avatar
Default Re: JRSC fitment issue (greekspeed)
see my signature....i used a type R kit
Old Oct 18, 2003 | 11:10 AM
REX VT's Avatar
Default Re: JRSC fitment issue (keebler65)
I read your write-up , good info! It's a tight fit, should be even tighter with my engine bay since the original engine mounts are slightly more towards the firewall. But I've seen many EE8 (EF8's) cars equipped with the JRSC so I'm convident it will work. What's your current boost/ hp? SQM?
Old Oct 18, 2003 | 11:16 AM
MADEINIRAQ's Avatar
i just put a type r kit on mine too. tight fit but worth it
Old Oct 18, 2003 | 11:43 AM
keebler65's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by REX VT &raquo;</TD></TR><TR><TD CLASS="quote">I read your write-up , good info! It's a tight fit, should be even tighter with my engine bay since the original engine mounts are slightly more towards the firewall. But I've seen many EE8 (EF8's) cars equipped with the JRSC so I'm convident it will work. What's your current boost/ hp? SQM?</TD></TR></TABLE>
i'm still running the stock 6psi pulley but i plan on getting an LHT intercooler and upping the boost to about 10psi, maybe next spring.
volkanerr
Oct 21, 2010 11:56 PM
heyitzspikey
Apr 25, 2006 10:34 AM
breakneckvtec
Feb 17, 2003 01:25 PM
