manual boost controller vs electronic????
Old Oct 16, 2003 | 09:33 PM
gstintegra92's Avatar
Default manual boost controller vs electronic????
any thoughts on this??? im almost decided on a greddy profec b, but im hearing electronic boost controllers fail really easily, so can i get some imput?? thanks you guys i know i can count on you for good info..............
Old Oct 16, 2003 | 09:56 PM
civperc's Avatar
Default Re: manual boost controller vs electronic???? (gstintegra92)
I prefer MBCs. they help with spool, are cheaper, simpler, and art just more my style.
like you said, an EBC is just another piece of equip. that can go bad.
Old Oct 16, 2003 | 10:05 PM
SEFIxCivic's Avatar
Default Re: manual boost controller vs electronic???? (untensadude)
mbc tend to creep in my experience. others have better luck tho.
Old Oct 17, 2003 | 06:22 AM
Default Re: manual boost controller vs electronic???? (SEFI8LOxCivic)
ok should we make a vote here??? its 1-1 so far, any other comments??????
Old Oct 17, 2003 | 06:37 AM
boostsohfast's Avatar
I've went with both and although my manual boost controller does creep slightly, I still prefer it over my Greddy profec that I used to use.
Old Oct 17, 2003 | 06:42 AM
GreddySi99's Avatar
Default Re: manual boost controller vs electronic???? (boostsohfast)
Blitz SBC or a greddy profect B 2 those are what I would use
Old Oct 17, 2003 | 10:54 AM
yea i think im gonna go with a manual one to start, and see how it works for my setup, any suggestions on a good mbc??? thanks for your help everyone
Old Oct 17, 2003 | 10:57 AM
civperc's Avatar
I suggest TurboXS.
Old Oct 17, 2003 | 11:31 AM
mike1114's Avatar
hallman makes good MBC's also. I got mine for like $30 from someone.
hallman also has one you can adjust from inside the car. Too much $$ for me thought.
Old Oct 17, 2003 | 11:44 AM
yellowturbo's Avatar
My EBC is fine.. I use AEM EMS with the Gm boost solenoid... No problem with it ...
Old Oct 17, 2003 | 11:50 AM
twkdCD595's Avatar
Default Re: (yellowturbo)
a homemade or cheap mbc's will creap, but I have heard good things about the hallman, turboxs, tvvc, and whatnot more expensive quality units.
Old Oct 17, 2003 | 03:46 PM
AlphaKennyWun's Avatar
Default Re: (twkdCD595)
The difference is clear:
mbc pros: cheap
mbc cons: hard to accurately adjust; creep; few have in cabin access; open wastegate too early
ebc pros: easy to accurately adjust; less prone to creep; cabin access; open wastegate at last possible moment; more options
ebc cons; higer priced
Old Oct 17, 2003 | 04:36 PM
RenoRacing's Avatar
Default Re: (S03Burner)
then there's the homemade electric/manual boost controller that is always worth the 10$ in parts. I'm sure you've all heard the theory and the technique(map sensor purge valve thingy w/ little brass bleeder valves and a button or rpm switch to activate different boost setting) I have to say It works pretty good!
Old Oct 17, 2003 | 06:31 PM
gritsak's Avatar
Default Re: (RenoRacing)
im not sure where all these creep problems associated with a MBC are coming from...you guys are probably using ones with a bleed type valve instead of the ball and spring....IMO Hallman makes anout the best MBC..ive got one of the new ones with cockpit controll and its a really nice piece. they are just as easy to adjust as a EBC which the **** inside the car.
ive had better boost responce and control with a MBC..i would realy reccomending getting a hallman too.
Old Oct 17, 2003 | 06:36 PM
GSRrR's Avatar
Default Re: (gritsak)
friend had the turboXS high performace model on this greddy kit. it did creep so he sold it. thought the high performance was suppose to hold boost better?
alot of the profec B are gettting cheaper now because the spec II came out.
Old Oct 17, 2003 | 06:46 PM
boosted92's Avatar
Default Re: (GSRrR)
My car spooled my big twins a good 300 RPM's sooner with my profec-b than it did with a turboXS. Problem with MBC's is they will slowly allow boost to reach the wastegate spring/diaphragm which causes it to slowly creep open which causes slower spool. IMHO if you're running a tight budget and a fairly small turbo go with a MBC but if you have a lil more cash and a bigger turbo go EBC for sure.
Old Oct 17, 2003 | 07:23 PM
turbo Si's Avatar
Default Re: (boosted92)
I had an AVCR and it was a bitch to deal with. So I got a Turbonetics manuel boost controller and it works great. Held 23lbs with no problems!
Old Oct 17, 2003 | 08:54 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (turbo Si)
i have a blitz dual sbc, but had made a mbc and it is working quite well at 14 psi on my friends sr20. i used to use one on my buick at 26 psi but its an automatci and no gear changes. so creep wasnt a problem. i know of alot of people using ball and spring style controllers.
Old Oct 18, 2003 | 02:51 PM
Default Re: (GSRrR)
im gonna have to disagree on the profec b gettin cheaper, people on here sell them used for $250 which is too much, you can get it new for $300, if i could find one for like $175 which is about what its worth used i might pick it up, otherwise im gonna go hallman mbc.........
Old Oct 18, 2003 | 02:57 PM
GSRrR's Avatar
Default Re: (gstintegra92)
some people are crazy trying to sell the old ones used for so much. the new ones are 295 shipped....
Old Oct 18, 2003 | 03:00 PM
TurboJesse
Guest
Posts: n/a
Default Re: (GSRrR)
Im using the Greddy TVVC, got it used for $75. Works great holds 14psi steady and is easy to adjust
Old Oct 18, 2003 | 04:01 PM
BlackKnight7's Avatar
Hallman definitely makes a good boost controller, I would definitely recommend it. I know a lot of the dsm guys will not use anything else. I would say that mbc is the way to go. The only thing that electronic boost controllers have over mbc's is that some of them can be rpm sensative. So you can run different amounts of boost at different rpm. For the money a mbc is the way to go.
Jake d.
Old Oct 18, 2003 | 07:23 PM
PHiZ's Avatar
Default Re: manual boost controller vs electronic???? (BlackKnight7)
An EBC is going to operate of an electronic solenoid, which I'm going to say is not going to last as long, as is going to wear harder than a mechanical solution.
-PHiZ
Sinner
May 3, 2005 10:05 AM
tararan
Jan 22, 2003 06:01 PM
marklamond
May 10, 2002 02:17 AM
