Wastegate question
What is the diff between a .45 bar spring and a .7? Does it mean that you have to be pushing over .45 bar for the wastegate to open up? Sorry, i just dont see why you would get a .7 if that is the case. Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LilManSi »</TD></TR><TR><TD CLASS="quote">meainging the maximum boost you can run is .45 bar?</TD></TR></TABLE>
No that is your base psi, you can go higher with a boost controller, but no lower, make sense :
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LilManSi »</TD></TR><TR><TD CLASS="quote">but my question is, why would you pay more to get a .7 bar if the .45 bar does the same? </TD></TR></TABLE>
um last i checked it was the same price wether you got a .35 bar or .65 bar spring. It would only cost more if you decided to swap springs after you already bought the wg...
Acura_I-RS
Sep 15, 2003 04:43 PM
austrian type-R
Mar 18, 2003 12:15 PM
