best break in method??
Old Oct 16, 2003 | 11:01 AM
D@nnY's Avatar
Default best break in method??
Whats the best way to break in golden eagle sleeves and je pistons and rings? How many miles? Right now i am keeping it under 4k rpm. i was told 3000 miles before boost but i cant take that...helpp
Old Oct 16, 2003 | 11:43 AM
gritsak's Avatar
Default Re: best break in method?? (GSRT37)
do a search..this has been talked about sooo many times...and whoever told you 3k miles before boost is nuuutz
Old Oct 16, 2003 | 12:00 PM
Gravy's Avatar
Default Re: best break in method?? (gritsak)
drive it for 500 miles and then start beating on it.
Old Oct 16, 2003 | 01:59 PM
kpt4321's Avatar
Beat it hard, and LOTS of oil changes.
Old Oct 17, 2003 | 10:02 AM
D@nnY's Avatar
The car has 300 miles on it and i havent taken it over 4k still. do i need to punch it a little to break it in. ill be boosting it soon
Old Oct 17, 2003 | 10:06 AM
DC2R714's Avatar
Default Re: (GSRT37)
Just boost it but make sure you are tuned. I boosted 9psi when I had 67miles on my motor. The rings only take around 20miles to seat. Just make sure its tuned and boost away. If a problem is going to happen it will happen no matter when you boost it.
http://www.mototuneusa.com/break_in_secrets.htm
Old Oct 17, 2003 | 10:07 AM
BodyKits NW's Avatar
Default Re: (DC2R714)
25 miles and straight to the dyno. Good to go for me.
Old Oct 17, 2003 | 10:52 AM
Ri5e's Avatar
Default Re: (BodyKits NW)
2 Miles and straight to the dyno for me
Old Oct 17, 2003 | 06:51 PM
Kelly.'s Avatar
I've quit using this account
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2R714 &raquo;</TD></TR><TR><TD CLASS="quote">Just boost it but make sure you are tuned. I boosted 9psi when I had 67miles on my motor. The rings only take around 20miles to seat. Just make sure its tuned and boost away. If a problem is going to happen it will happen no matter when you boost it.
http://www.mototuneusa.com/break_in_secrets.htm</TD></TR></TABLE>
i checked in my manual.. it says to do the same thing that is in the link..
Old Oct 17, 2003 | 07:45 PM
xci_ed6's Avatar
Default Re: (llewsirc)
I prefer a spring loaded center punch. Somtimes I use a screwdriver or a slim jim though.
-Dustin
Old Oct 17, 2003 | 08:50 PM
boostedcivicsir's Avatar
Mr. Badwrench
when we built buicks, having an overhead valve design, we did 10 mins at 200.
30 mins cool down. 10 mins at 2500. 30 mins cool down. then 10 mins at 3000. then 500 miles change the oil than have fun. no synthetic till 10,000 miles. i am sitting at 670 on mine and just waiting on the hondata.
Old Oct 17, 2003 | 10:02 PM
hondahvn's Avatar
Default Re: (boostedcivicsir)
how long do you think kenny tran or gary gardella break in their motors? if the rings are gonna seat theyll seet quick way quicker than 500 miles probably quicker than 50 miles. who realy knows. break in times is like the age old question boxers or briefs. its all an opinion. for every poor sob that broke his motor in for 600 miles plus and blew it up as soon as he pushed it hard there is one who didnt break his in and did the same thing so just do what makes you comfortable. my standard rule of thumb is drive soft until its tuned then beat the **** out of it thats what we build em for anyway
Old Oct 17, 2003 | 10:04 PM
Mr. Badwrench
Default Re: (hondahvn)
i was tought break it in how you are gonna drive it.
Old Oct 17, 2003 | 10:27 PM
VaporTrail's Avatar
New User
some types of rings seat faster than others, and it depends too on what type of wall you are using (steel, iron), piston to wall clearance and a few other scant details. I prefer a gradual break in, minimum 100 miles but no more than 500 is really needed. When I say gradual, I mean during the break in period, increasing rpm and intervals of abuse, as well as load. While the main portion of seating happens just during idle or high speed idle, more high RPM is needed for full seating. Taking a longer break in period can help you avoid failures while on the dyno by finding problems under lighter loads and fixing them before they become disasterous.
Old Oct 18, 2003 | 09:13 PM
T4eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BodyKits NW &raquo;</TD></TR><TR><TD CLASS="quote">25 miles and straight to the dyno. Good to go for me. </TD></TR></TABLE>
Old Oct 18, 2003 | 09:21 PM
60-1teg's Avatar
Default Re: best break in method?? (Gravy)
yea what he said.
Old Oct 18, 2003 | 09:58 PM
BoostedH23a1's Avatar
Default Re: best break in method?? (2.0lhatch)
y not be totally safe and baby her for a few hundred... unless u plan on rebuilding all hte timel..
Old Oct 18, 2003 | 10:10 PM
RAWB's Avatar
Good method
97turboteg
May 25, 2006 06:22 AM
jaxx4k
Oct 26, 2004 01:45 PM
DB2
Jun 18, 2003 06:17 AM
DLB1994
Sep 2, 2001 03:47 PM
