boost leak
Old Oct 17, 2003 | 08:25 AM
dominate9's Avatar
Default boost leak
What methods are there for identifying boost leaks? I don't think it's a vacuum leak because the engine idles fine. All my piping is connected tight. My manifold is missing one bolt that connects it to the block, but all others are tight. I don't have a dumpt tube on my Tial yet. I disconnected the wastegate and ran like that. Still no boost. So that rules out the wastegate. I'm stumped. HELP!
Old Oct 17, 2003 | 08:40 AM
boonacka's Avatar
Default Re: boost leak (dominate9)
check your bov? egr? charcoal canister?
Old Oct 17, 2003 | 09:53 AM
dominate9's Avatar
Default Re: boost leak (boonacka)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boonacka &raquo;</TD></TR><TR><TD CLASS="quote">check your bov? egr? charcoal canister?</TD></TR></TABLE>
All those are straight. ANy techniques to finding leaks?
Old Oct 17, 2003 | 10:25 AM
Ricey McRicerton's Avatar
Get a small hose (3/8. 1/2) and put it in your ear...run it along the piping and other things that possibly could be leaking and you can actually hear where the air is leaking. Best of luck with it.
Old Oct 17, 2003 | 11:54 AM
platinum00's Avatar
Default Re: boost leak (Ricey McRicerton)
get a 2.5 inch cap at home depot, drill a hole in it. put a bike tire stem in it. glue it down good. wait till it drives.
hook that up to the end of you piping with another silcone coupling, and pump away. you will find leaks all over the place. 100% sure.
platinum.
Old Oct 17, 2003 | 12:01 PM
CzanSOHC's Avatar
Default Re: boost leak (platinum00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 &raquo;</TD></TR><TR><TD CLASS="quote">get a 2.5 inch cap at home depot, drill a hole in it. put a bike tire stem in it. glue it down good. wait till it drives.
platinum.</TD></TR></TABLE>
do you have this already made up? i need to try it
Old Oct 17, 2003 | 01:22 PM
platinum00's Avatar
Default Re: boost leak (CzanSOHC)
yea i got one sitting in my garage im not using.
im about reading to start making them and selling them. hehe
if you wanna use it let me know
platinum..
Old Oct 17, 2003 | 11:23 PM
dominate9's Avatar
SOLVED
THANKS GUYS!
Old Oct 18, 2003 | 05:11 AM
civictypenos's Avatar
another solution is to get a bicylcle inner tube,cut it in half and clamp it down over both sides,then inflate it.it already has a tire stem in it.you only need to test up to 30 psi at the most.
Old Oct 21, 2003 | 05:33 AM
boonacka's Avatar
Default Re: boost leak (civictypenos)
so where was the leak?
97dc2
Jun 7, 2005 02:22 PM
91glassycrx
May 7, 2004 08:08 AM
PKSPX
Jun 28, 2003 03:45 PM
turbo se
Jun 24, 2003 08:12 AM
Smashback
Jul 11, 2002 08:49 PM
